Results 1 to 18 of 18
    Mar 2011
    The Universe
    I have spent days attempting this and I am fed up enough to simply beg the help of the community. I use handbrake to encode my videos but the audio encoder present (faac) is sub par to nero. So I encode the video, Closed Captions, and Chapters with Handbrake and the audio with nero through megui.
    My Problem is thus: I Need to mux the video file with multiple audio files such that it is itunes compatible.
    I have tried Many gui's over the past couple of days and experimented with the MP4box CLI to no avail. Quicktime will do what I want in an .mov file but I need an .mp4 or .m4v. Both quicktime and MP4Box will only give me a single audio track as output. MP4Muxer gives me both tracks (audio and commentary) but they play simultaneously in Itunes.
    I've read that MP4Box is capable of this but I haven't been able to acomplish it. A simple guide (or extensive if you're feeling generous) would set my world right, however any help, tips, advice, or links would be appreciated.
    Try a mp4box gui like mymp4boxgui or yamb.
    Oct 2005
    666th portal
    [edit] sorry didn't read the op's post well enough
    Mar 2011
    The Universe
    Wow, thanks for the quick responses but I've tried both, either I'm doing something wrong (probable) or I need to use the CLI or another program. Any advice is, of course, welcome.
  5. Member bat999's Avatar
    Feb 2008
    Originally Posted by FaiT View Post
    or I need to use the CLI .
    Hi
    If you use MP4Box from CLI the command is like this:-
    MP4Box -add video.mp4 -add sound1.aac -add sound2.aac output.mp4
    Test it with a short clip first to see if the result is itunes compatible.
    Mar 2011
    The Universe
    Thank You. I will try now but I've already tried some thing similar (add -new) and it didnt work. Testing now and will report the results. Again, Thank You for showing an interest to help me.
    Exact CLI "mp4box -add video.mp4 -add audio1.m4a -add audio2.m4a output.mp4"
    Mar 2011
    The Universe
    The result played in VLC with only one audio track (the first one). It froze itunes when I tried to add it. My video file is h.264 and my audio tracks are 80kbs ABR AAC-HE (SBR).
    Mar 2011
    The Universe
    Something interesting, it may have only played one audio track but the file size indicates that it contains both.
  9. Member bat999's Avatar
    Feb 2008
    VLC > Tools > Codec Information > Codec Details
    Will show you what's inside the file.
    Also MediaInfo program.
    Mar 2011
    The Universe
    VLC indicated it had only one audio stream
    mediainfo said this:
    General
    Complete name : C:\Users\FaiT\MP4Box\output.m4v
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 937 MiB
    Duration : 1h 44mn
    Overall bit rate : 1 256 Kbps
    Encoded date : UTC 2011-03-23 22:21:51
    Tagged date : UTC 2011-03-23 22:21:51
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 11 frames
    Codec ID : avc1
    Duration : 1h 44mn
    Bit rate mode : Variable
    Bit rate : 1 090 Kbps
    Maximum bit rate : 12.0 Mbps
    Width : 720 pixels
    Height : 368 pixels
    Display aspect ratio : 2.35:1
    Frame rate mode : Variable
    Frame rate : 23.953 fps
    Minimum frame rate : 3.112 fps
    Maximum frame rate : 227.848 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.172
    Stream size : 814 MiB (87%)
    Writing library : x264 core 114
    Encoding settings : cabac=1 / ref=11 / deblock=1:0:0 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=0 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=0 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Encoded date : UTC 2011-03-21 07:03:30
    Tagged date : UTC 2011-03-23 22:23:02
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio #1
    Format : AAC
    Format profile : HE-AAC / LC
    Codec ID : 40
    Duration : 1h 44mn
    Bit rate : 80.0 Kbps
    Maximum bit rate : 112 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz / 24.0 KHz
    Compression mode : Lossy
    Stream size : 59.7 MiB (6%)
    Encoded date : UTC 2011-03-23 22:22:59
    Audio #2
    Format : AAC
    Codec ID : 40
    Duration : 1h 44mn
    Maximum bit rate : 98.6 Kbps
    Encoded date : UTC 2011-03-23 22:23:00
    But Vlc will only recognize the first audio stream and itunes freezes when it tries to add it.
  11. Member bat999's Avatar
    Feb 2008
    I believe MediaInfo.
    Make sure you're using an up to date VLC.
    Mar 2011
    The Universe
    Thanks but the point is moot, even if it did play in vlc I need it to play in Itunes (ipod) and it freezes itunes when I try to import it.
    Mar 2011
    The Universe
    Just tried this on another computer in case it was something local and the results were the same.
    Mar 2011
    The Universe
    Ok, Bat999, you were right about vlc. I switched to media player classic and it does recognize the audio which leads me to believe that the files I have been making this whole time have been fine. It won't add to Itunes but I suspect it could be because my video is too complex (ref frames might be too high) so Im gonna experiment.
    I continue to welcome any insight or experience anyone here might have or any guides or links to guides on the subject. My continued apreciation to you all .
  15. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    make sure your level is 3.1 and profile is main.
    Mar 2011
    The Universe
    SOLVED! Thanks Everyone for your help. It was my fault the video wouldn't add to ITunes as for the audio this http://sourceforge.net/projects/gpac/forums/forum/287547/topic/2345177 will tell you everything you need to know (In case you're a lurker with the same problem) Basically Itunes requires you define the audio alternate group and that you disable all but the main track by default so a video with two audio tracks would look like this
    mp4box -add video.m4v:lang=en -add audio1.m4a:group=1:lang=en:name="Dolby Surround" -add audio2.m4a:disable:group1:lang=en:name="Director's Commentary" output.m4v
    "name=X" doesn't seem to work in Itunes but I thought I'd leave it in anyway since some players do read it (just not my ipod ).
    If anyone could show me how to add language names to the audio streams, such that when I select them in my player it shows English, French, etc..., It would be much appreciated .
    Feb 2004
    Perhaps this?
    -name trackID=NAME : sets track handler name. Handler name is sometimes used to identify the track content (for example, audio language).
    Source:http://gpac.wp.institut-telecom.fr/mp4box/mp4box-documentation/
    PB
  18. Member
    Mar 2011
    The Universe
    Thank You for posting! I tried that and Itunes won't recognize it. media player classic and mediainfo will but not Itunes. If anyone knows how to get Itunes to recognize track names with mp4box or any other program please let me know.
