I bought a usb video capture called easy cap and it works. The only problem is the sound is not clear. My program called Honestech VHS to DVD has a drop down menu for sound and I can use the usb for sound and it works but it is not clear. When I select from the drop down menu the intergraded sound from my computer, I don't get any sound at all. Does anyone have any idea what I could do to get better sound? Should I buy a video card and use the video instead of the usb? Should I buy a sound card and would that give me sound from my computer since it does not work from my intergraded sound? Should I buy better video audio cables from my vhs to the usb easy cap also called grabber 2.0?
As life will have it I coudn't wait for an answer. I bought a more recent version of Honestech and it came with a different usb video capture and the sound is so much better. It was worth the cost for me. As long as I use long dvd from a drop down menu the video is not split.
Absolutely no clue. What is your capture hardware?
Oh easycap. I don't have it so can't comment.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
VHS to S Video Capture Help
By bob52 in forum Capturing and VCRReplies: 11Last Post: 2nd Mar 2012, 02:17 -
EP VHS video capture
By Lucky Starr in forum Capturing and VCRReplies: 11Last Post: 27th May 2011, 01:09 -
Trying to capture video from VHS
By JoshGlzBrk in forum Capturing and VCRReplies: 1Last Post: 19th Dec 2009, 22:33 -
VHS/ DVD Go-Video problem. Bad video, good audio
By Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 21:31 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42
