    Jan 2007
    Europe
    Hello,
    I recently downloaded a cartoon for my son which is in avi format. But I guess there is also a vp6 codec (which Im not familiar with) needed to play it. I downloaded the vp6 codec and can only play using windows media player (normally I would never use this). The problem is I dont want to play this on the computer, I want to burn it as an avi to disc, to watch on my DVD player. The problem is I cant find any program that will convert it. any suggestions? here is a log from mediainfo:
    Complete name : #######
    Format : AVI
    File size : 160 MiB
    Duration : 22mn 39s
    Overall bit rate : 986 Kbps
    Writing library : TMPGEnc 3.0 XPress Version. 3.0.4.24
    Video
    Format : VP6
    Codec ID : VP60
    Codec ID/Hint : On2
    Duration : 22mn 39s
    Bit rate : 920 Kbps
    Width : 512 pixels
    Height : 384 pixels
    Display aspect ratio : 4/3
    Frame rate : 29.970 fps
    Resolution : 16 bits
    Bits/(Pixel*Frame) : 0.156
    Stream size : 149 MiB (93%)
    Audio
    Format : MPEG Audio
    Format version : Version 2
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 22mn 39s
    Bit rate mode : Constant
    Bit rate : 56.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 24.0 KHz
    Stream size : 9.08 MiB (6%)
    Alignment : Split accross interleaves
    Interleave, duration : 125 ms (3.75 video frames)
    Try convert to avi xvid with xmedia recode or winff.
  3. Note that many conversion programs use Windows VFW codecs (VirtualDub, for example) not the DirectShow codecs used by media players. So you may need a VFW VP6 decoder. If so, ffdshow includes one.
