Results 1 to 14 of 14
    Mar 2011
    San Diego CA
    Im having a problem when using deshaker. My saved avi file has white arrows in it, I know this is the first pass . It doesnt perform the second pass , and that what I get for output video. I have read the instructions at both here
    http://www.sundancemediagroup.com/articles/deshaker_guide.htm
    and here
    http://www.guthspot.se/video/deshaker.htm
    but everytime I try to output a useable video from save to avi I get the dub video on the left side of the split screen. ]
    Help
  2. Do you have Video -> Full Processing Mode enabled?
    Nov 2009
    Set up for your first pass in the deshaker dialog, then in VirtualDub in the "File" menu list do "Run video analysis pass". When that finishes, open up the deshaker dialog and click on the "Pass 2" button and set up the options. Close the dialog and now do the "Save as AVI". Each pass has to be run manually.
    Mar 2011
    San Diego CA
    Thanks for the replys. I checked my versions of vdub and deshaker, they were so old I decided to download the latest version of each. Now my plug ins for MP4, mov, flv ect no longer work. So now I have to find the fix for that. I was running everything as you guys stated above , except I dont know if I had full process mode checked.
    But now I cant pull an Mp4 into vdub so I have to work on that before I can re-try
    Mar 2011
    San Diego CA
    Still not able to get Deshaker to work. I have the newest version 2.7 and I still get the same results. I have full processing mode enabled , I run the video analysis pass , save as avi and ever time I have the same thing. A video with white arrow everywhere.
    Why cant I get this to work?
  6. Originally Posted by splitboarder View Post
    You probably didn't hit the pass 2 button
    it should be: go back to the configuration after the video analysis pass, hit pass 2 button, configure the options, then save as avi
  7. Set Deshaker to Pass 1, run analysis pass, set Deshaker to Pass 2, Save as AVI.
    Nov 2009
    Deshaker requires 2 passes. In the Deshaker config dialog hit the Pass 1 button and configure as required. Close the dialog and in the File menu click "Run video analysis pass". This will run the first pass, creating the text file that contains the motion data for each frame. When this finishes, go back to the Deshaker config dialog and hit the Pass 2 button and configure as required. Close the dialog and select your video codec for compression. Go to the File menu and select "Save Avi". This will run the second pass, reading the motion data file that was created in the first pass and adjust the video motion to how you set up the pass 2 parameters and send the modified video to the video encoder.
  9. You can run Pass 2 multiple times with different settings and see the differences the various settings make.
    Mar 2011
    San Diego CA
    Ah Thanks for the quick replys. I think Khaver is on to something. I am hitting the second pass , every time. And after hitting "pass2" , setting it up (pass two) and closing the dialog box and save avi I still get white arrows. The only new thing I see is Im not picking a codec.
    I thought if you didnt choose a codec, Vdub would do the pass without compression. I will try that when I get home
    But, yes I have been doing two pass set up , it just seems vdub isnt doing anything with the second pass
    Mar 2011
    San Diego CA
    While the second pass is being dubbed will I see the first pass in the input (left) frame? Thats another thing I notice. The left pane ( input) always shows the original video file. On the second pass should the left pane have the first pass shown ?( with the arrows?)
    I never see any change while running pass two
  12. Originally Posted by splitboarder View Post
    The input pane always shows the input video.
    The input pane always shows the input video. It should not be showing you the result of the first pass unless you saved the result of the first pass as a video and then opened that video as the source video. You should leave the original input video as your source video.
    1) Open source video
    2) Add Deshaker filter
    3) Set Deshaker to Pass 1, setup any pass 1 parameters
    4) File -> Run Video Analysis Pass
    5a) Go back to the deshaker dialog and select Pass 2, setup any pass 2 parameters
    5b) See the results by scrubbing through the video, go back to step 5a if necessary
    6) File -> Save as AVI
    Mar 2011
    San Diego CA
    Im on another forum discussing this. I think they have the answer. When I set up the second pass and hit ok the filters box comes up showing what filters have been applied. I have been told to uncheck pass one . I do remeber both passes having checks each time I have tried to render out.
    I think this may be the problem. I will try it when I get home
    It has been, I was just checking to see if I had that part right
    Thanks again
  14. Only add one instance of the Deshaker filter.
