I just downloaded and installed firefox4.
It seems pretty nice. I like the larger screen without that bar at the bottom - even though it was small it still took up room.
It does seem a bit faster. I'm using it on an old single core celeron using a wireless connection to my cable internet through a wireless router in another room. So far it seems like videohelp.com is loading just a tad faster.
It also seems streamlined more. It doesn't look cluttered at all.
Do you have it yet? Do you like it?
Edit - yahoo email definitely loaded faster with firefox 4. It seems like its loading the ads and stuff like that more quickly and efficiently. Thumbs up!
Results 1 to 30 of 96
FF4 loads quicker and is more stable than FF3.
The only issue is a lot of plugins don't yet work on FF4 -- not ones I want, at least.
I like it, and it's on all but my main computer.Want my help? Ask here! (not via PM!)
Fast and efficient and is on all my computers. The sync function works well and saves work. Way to go FF!
Did it just release today or was it already out?
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I thought FF4 was still in RC releases? Huh. I'll have to go check.
I'm not at a system with FF3 installed, so I'll have to check this, too... but couldn't you have just turned the status bar off in the View (> Show >) menu, or used full-screen mode?It seems pretty nice. I like the larger screen without that bar at the bottom - even though it was small it still took up room.
I prefer to have the status bar visible, anyway.
If cameras add ten pounds, why would people want to eat them? -
@ai haibara - I'm not a firefox expert so I wouldn't know. Heck I don't even know where to get most of the add ons. I just use a few that I've searched for on purpose.
I tried Firefox4 some time ago and liked it - particularly the 'panorama' feature to organise the tabs.
But as lordsmurf says, it had limited plugin support. This seems to have changed recently as the plugins that I use are now available for it.
I've just downloaded the latest version and it does indeed feel significantly more responsive. Looking good so far.
Looks like the final version was released today, according to Wikipedia and the directory dates on this site:
http://releases.mozilla.org/pub/mozilla.org/firefox/releases/
The last RC2 release was dated the 18th March. -
So far, I like FF4. It does seem to have a lot quicker response and the layout seems much cleaner. The plugin suport is not an issue for me, but I'm sure it they will catch up in due time. Overall, I give it a "thumbs up".
Also, this is pretty cool. It looks like FF4's acceptance is quite strong.
http://glow.mozilla.org/ -
I installed it on a friends computer that I use when I'm at his house and I uninstalled it because it looked like Chrome. Got home and installed the portable version on a thumbdrive and played with the settings until I got it to look like I had 3.6 looking (like IE6) and decided to upgrade my version to 4. My Tabkiller plugin and a couple of DivX plugins didn't work but I checked the speed in IE and Firefox 4 and the download speed was 3 MBps faster in Firefox 4. Firefox 3.6 seemed to be about the same as IE before.
It doesn't have the information bar on the bottom like 3.6 had but real estate is one of my biggest concerns with a browser so that's OK, I guess. -
It's weird I just installed it on my vista pc and it had me reboot after the installl! I didn't have to do that on my xp machine. Weirdness.
But hey it works great and thats all I want.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
By default, no, but you can put it back. FF4 reports status of page loads etc in a small tab that appears as needed in the bottom left corner. However if you like having the old style status bar, especially because it contained the status icons of various plugins, you can right-click your mouse next to the tabs at the top, and select Add-on Bar from the list.
Read my blog here.
Also tried to install FF4 on an iBook G4 - didn't get far, as Firefox has dropped support for PowerPC based systems.
On Windows 7, do I need to save the installer and "Run as Administrator", or will just running from the download link suffice?
Thanks! When I'm using the Stylish plugin then I need to be able to easily enable and disable styles.
I found a plugin called Menu Editor that allowed me to get rid of "open in a new tab" so by turning off tabs and using the menu editor, I don't need the Tabkiller plugin that FF4 does not support. -
Follow up comment on my own post...
After posting this I did a little research and found that FF4 is not officially released in 64 bit for Windows, although you can download and use the 64 bit Windows builds they do on a nightly basis. The reason is that "not enough plugins are available in 64 bit". As one guy put it something like this - "Your refusal to officially release a 64 bit Windows version is why few 64 bit plugins are available. People aren't going to make 64 bit plugins until you release a supported browser that people start using and there ends up being demand for 64 bit plugins". So since I live plugin free I have no reason to not try the 64 bit compile, but those of you who use plugins will have to wait.
Word is that FF5 will officially support 64 bit Windows, but I wouldn't even guess when that will come out. -
what happened to the little drop down list of the previously visited websites in the back arrow? You could drop the list down and choose the page from a list of like 8 or 10 recently visited pages. Is that still doable?
Great thanks!Originally Posted by intracubeDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
http://portableapps.com/apps/internet/firefox_portable
EDIT: The portable version was very slow to start up which is why I went ahead and installed the normal version.Last edited by DarrellS; 24th Mar 2011 at 01:01.
I have to wonder why they put the Home button so far on the right. It belongs next to the WOT and NoScript buttons. Anyone know how to move its location? Thanks
If I'd known I was going to live this long, I'd have taken better care of myself. -
Greasemonkey plugin with Youtube HD Ultimate script doesn't work but I found another plugin to replace it with. Scriptish with Youtube HD Suite.
I just installed IE9, I must be the last person that still uses IE.
Your numbers are declining, but a lot of home users still use IE. Keep in mind that we are a technical website so our members are more likely than the average person to use things like FireFox. I have to take my victories where I can get them. I've gotten my brother's family to get away from IE, but my dad refuses to leave IE and he knows that it had plenty of security problems in the past.
I use Opera to surf on my Windows PC (Safari/Camino on the Apple) ...FireFox became to bloated(Much like IE). Opera is still IMO faster and a better overall browser. I'll skip Firefox again.
PS I still miss Netscape -
Thanks that did it. WOT is web of trust, http://www.mywot.com/ WOT’s traffic-light style rating system Green means safe, yellow means caution and red means stop. It’s easy, and it’s free
Almost all of my replay media catcher recordings have generic file names (8D3F7A54_videoplayback.mp4) from Youtube and VEVO when using Firefox 4. They all have their original file names when recorded using Internet Explorer. Usually if I got a generic file name, I could copy the file name from the url in the properties window but it's not showing it there either.
Nintendo ds xl impressions.
By johns0 in forum Portable VideoReplies: 5Last Post: 26th Mar 2011, 20:42 -
WD TV Live Hub First Impressions
By TBoneit in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Nov 2010, 16:09 -
Personnal impressions on MEGUI
By Cunhambebe in forum Newbie / General discussionsReplies: 0Last Post: 30th Apr 2008, 20:57 -
Samsung TX-T3093WH (HD CRT TV) first impressions
By Leoslocks in forum DVB / IPTVReplies: 0Last Post: 6th May 2007, 14:07 -
Beta 2.5 first impressions
By mesaboogieman in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th May 2007, 19:25
