Hi, I've been converting m2ts files for some time now, with avs2dvd. I've been using default settings in avstodvd, except path directory, and ntsc. When converting an m2ts I've always used QuEnc as the video encoder (locking the bit-rate), and adjusted the audio encoder to QuEnc as well. Things have always worked great.
However, I've tried 3 separate m2ts sources (one an already confirmed/converted source just to be sure), and I'm getting the same results.... out of sync audio. The video will play no sound for a bit in the beginning, and when checking mid length, I get seriously out of sync audio. I have viewed through VLC, MPCHC, etc, to see if it was a specific player. Problem remains.
I can only assume something is "broken" and I have uninstalled/re-installed avstodvd, vlc, and my CCCP filter pack. I have also allowed avstodvd to choose its own settings with the same problem. I am in the process of converting right now, so results will be in shortly.
Thanks ahead of time, I will post a log from one of my earlier tests.
(ps I noticed an 'audio delay' section in the log, could this be the issue?
<3/20/2011 11:37:45 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Documents and Settings\My Documents\Videos\convert_x
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 2500
Video Profile Level 2: 2500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 2
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language: EN - English
DVD Subs Language: EN - English
DVD Subs Font: Tahoma 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: HP DVD Writer 1270d GH24
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\My Documents\Videos\convert_x\source_files\test.m2ts
Info: AVC - 3636 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:05:08 hours - 180028 frames
Audio 1: C:\Documents and Settings\My Documents\Videos\convert_x\source_files\test.m2ts
Info: AC3 - 640 kbps - CBR - 6ch - 48000Hz - 16bit - 2:05:08 hours - Internal
Subs:
[MediaInfoLib - v0.7.41]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Documents and Settings\My Documents\Videos\convert_x\source_files\test.m2ts" , CacheFolder="C:\DOCUME~1\~1\LOCALS~1\Temp", FrameRate=23.976, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("C:\Documents and Settings\My Documents\Videos\convert_x\source_files\test.m2ts" , CacheFolder="C:\DOCUME~1\~1\LOCALS~1\Temp")
# Workaround to fix QuEnc multichannel audio mapping bugAudio = Audio.GetChannel(1,3,2,5,6,4)
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Spline64Resize(720,480)
Audio = Audio.DelayAudio(600)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 3933.3 MB
QuEnc Parameters: -i "C:\DOCUME~1\~1\LOCALS~1\Temp\test.avs" -o "C:\Documents and Settings\My Documents\Videos\convert_x\test.m2v" -b 4394 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
<3/21/2011 1:58:17 AM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: C:\Documents and Settings\My Documents\Videos\convert_x\test.m2v (3933 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4394 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:05:01 hours - 179847 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "C:\Documents and Settings\My Documents\Videos\convert_x\test.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
<3/21/2011 2:03:58 AM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Documents and Settings\My Documents\Videos\convert_x\test.m2v (3933 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4394 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:05:08 hours - 180025 frames
START AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 2 -i "C:\DOCUME~1\~1\LOCALS~1\Temp\test.avs" -y -vn -acodec ac3 -ac 6 -ar 48000 -ab 448k "C:\Documents and Settings\My Documents\Videos\convert_x\test.ac3"
<3/21/2011 4:00:38 AM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Documents and Settings\My Documents\Videos\convert_x\test.ac3 (401 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 2:05:08 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\~1\LOCALS~1\Temp\DVD_0_BatchMux.i ni"
BatchMux ini file:
-d "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0\VIDEO_TS"
-mxp "C:\DOCUME~1\1\LOCALS~1\Temp\DVD_0_MuxMan.mxp"
-l "C:\DOCUME~1\\LOCALS~1\Temp\DVD_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "C:\Documents and Settings\My Documents\Videos\convert_x\test.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\My Documents\Videos\convert_x\test.ac3"
-a1lang en
-cellfr "C:\Documents and Settings\My Documents\Videos\convert_x\test.txt"
-progfr "C:\Documents and Settings\My Documents\Videos\convert_x\test.txt"
-chapfr "C:\Documents and Settings\My Documents\Videos\convert_x\test.txt"
<3/21/2011 4:12:40 AM>
CHECK DVD SIZE
DVD Folder (actual) Size: 4423.2 MB
vs Estimated Size: 4450 MB -> 0.6% undersize
vs Assets Size: 4334 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0 (4423.2 MB)
<3/21/2011 4:12:41 AM>
Log file created by AVStoDVD Release 2.3.4
Results 1 to 18 of 18
Second try after re-installs result in the same error. I assume it is the same issue so hopefully the above log with be sufficient.
problem solved... method = download multiavchd, follow AdubVideo's tutorial, and everything comes out crystal clear. Easiest gui I've dealt with so far. avstodvd has my respect, and will still be used, but I definitely have a new favorite for blu-ray converts.
MediaInfo has (wrongly?) detected an audio track delay in your m2ts of 0.6 seconds. That's why in the AviSynth script there is following command:
and that's probably the reason of the out-of-synch.Code:Audio = Audio.DelayAudio(600)
In addition, I strongly suggest you to use 'Wavi+Aften' instead of 'QuEnc' as audio encoder.
Bye -
Thanks for the reply. The reason I select quenc for audio was based off of adubvideo's tutorial. At the time I couldn't get m2ts to convert at all. I don't remember which version I was using. At that point selecting quenc worked, and well. Wavi+Aften always failed. I'll try it again. How is an audio delay getting into each conversion I make? It's the same with 5 different source files I tried.
I'm a very basic user, and avstodvd has been great until this recent problem. Is there a way for me to deal with the audio delay? I'll poke around in the meantime. Again thank you for the reply. -
AVStoDVD recognizes (using MediaInfo library) if there is a delay in audio tracks. If yes, by default, then the delay is fixed using the AviSynth DelayAudio() filter.
If the auto delay adjust routine does not work with your m2ts, you can de-activate it in 'Preferences'/'Audio'/'Auto Adjust Delay'.
Bye -
Audio/video sync problems are not uncommon using AVStoDVD on blu ray m2ts files. My copy of Winter's Bone went off sync by 2 seconds when I made a dvd from it, and took a lot of adjustment with AviDemux to correct it. I was using Wavi+Aften in AVStoDVD. This was the third blu ray movie I've had these kind of problems.
@Mr_C
Thanks! I'll give it a try. Seems I'm having just about the same amount of trouble with multiavchd now as I do with avstodvd. Common denominator must be my inexperience.
You've got a great program, and I appreciate the reply.
@Kerry56
Try using quenc as the audio encoder (and video for that matter). It's always worked for me up to this point. I'm gonna give the recommended above a shot after I re-install mediainfo/update things.
Or you could try multiavchd. Adubvideo's got a tutorial you can google on making sd-dvd's from BD or HD sources. Here --> http://adubvideo.net/how-to/converting-bluray-sd-dvd-multiavchd ... Between these 2 free programs you should get it done. Sometimes I'll fly through 10 conversions, and then stump myself for a day on just 1. Kills me, good luck. -
Right now I'm testing by backing up my BD vers. of 'The Godfather.' I've chosen quenc as the video encoder (locking bit rate), left wavi+aften BUT deselected the auto audio adjustment tick mark. I'll know in about 1 more hr. Then I'll post the results.
I wasn't sure if the tick mark should be left alone (present) UNTIL I get the same error. However, the last try I did was with 4-5 other movies, and they all had the 'same' problem. I'm thinking maybe mediainfo was screwy. I think about 2-3 versions of avstodvd ago, I had another problem with mediainfo. Should I not have mediainfo installed separately? Avstodvd will work without it?
One quick question. Is there a way for me to easily determine which encoder I should be using? Bit rates? Should I be trying to find the one that is closest to the source bitrate? Also, I've used the 'lock' button with quenc so that it's 2500-8500. Is this necessary? For a while it was the only way I could even get my m2ts's to load. As stated before they worked fine until recently, using quenc vid, quenc aud, and locking the bit rate. I've had like 6 months of smooth sailing with NO errors until this last run. I've re-installed latest versions of everything (cleaning up reg keys etc) and was still getting the prob, hopefully in a minute I'll find the answer!
@ MR. C
everything has been doing well since unticking the delay box. However, shouldn't it be toggled on? Normally? I just tried another video and found that the audio was off again, when I tested leaving the box marked. Seems no matter what I re-install which includes all my codecs (CCCP pack), all my a/v programs, media info, etc, cleared all reg values, rebooting multiple times, downloading new and updated versions, yet still....
here's the log.. Everything's the same, and I notice the audio delay set to 600 again. Strange. Should I uninstall mediainfo? I rarely use it, but it is handy.. could it be getting screwy some how?
<3/30/2011 3:20:33 PM>
START PROCESS
PROJECT SETTINGS
DVD Titles number: 2
DVD Size: 4449/4450 MB (100%)
DVD Label: DVD
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
Video Resolution: 0
AC3 Audio Encoder: 0
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
Save Log file: 1
Video: C:\Documents and Settings\My Documents\Videos\TV\3. Legends.m2ts
Info: AVC - 4222 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 55:10 minutes - 79368 frames
Audio 1: C:\Documents and Settings\My Documents\Videos\TV\3. Legends.m2ts
Info: AC3 - 640 kbps - CBR - 6ch - 48000Hz - 16bit - 55:10 minutes - Internal
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\My Documents\Videos\TV\3. Legends.m2ts", CacheFolder="C:\DOCUME~1\LOCALS~1\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("C:\Documents and Settings\My Documents\Videos\TV\3. Legends.m2ts", CacheFolder="C:\DOCUME~1\LOCALS~1\Temp")
Target Video FileSize: 2123.2 MB
QuEnc Parameters: -i "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_Title_01_3. Legends_1.avs" -o "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends.m2v" -b 5381 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
<3/30/2011 4:27:18 PM>
Created File: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends.m2v (2123.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5381 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 55:06 minutes - 79288 frames
DGPulldown Parameters: "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
<3/30/2011 4:31:17 PM>
DGPulldown executed on File: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends.m2v (2123.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5381 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 55:10 minutes - 79366 frames
Wavi+Aften Parameters: "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_Title_01_3. Legends_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends_1.ac3"
<3/30/2011 4:33:08 PM>
A2DAudioSource: DirectShowSource
Created File: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends_1.ac3 (208.8 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 1:05:10 hours
TITLE 2 SOURCE FILES
Video: C:\Documents and Settings\My Documents\Videos\TV\4. The Thing in the Pit.m2ts
Info: AVC - 4829 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 49:09 minutes - 70728 frames
Audio 1: C:\Documents and Settings\My Documents\Videos\TV\4. The Thing in the Pit.m2ts
Info: AC3 - 640 kbps - CBR - 6ch - 48000Hz - 16bit - 49:09 minutes - Internal
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\My Documents\Videos\TV\4. The Thing in the Pit.m2ts", CacheFolder="C:\DOCUME~1\LOCALS~1\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("C:\Documents and Settings\My Documents\Videos\TV\4. The Thing in the Pit.m2ts", CacheFolder="C:\DOCUME~1\LOCALS~1\Temp")
Target Video FileSize: 1892.3 MB
QuEnc Parameters: -i "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_Title_02_4. The Thing in the Pit_1.avs" -o "C:\Documents and SettingsMy Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit.m2v" -b 5381 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
<3/30/2011 5:33:48 PM>
Created File: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit.m2v (1892.3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5381 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 49:06 minutes - 70656 frames
DGPulldown Parameters: "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
<3/30/2011 5:37:01 PM>
DGPulldown executed on File: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit.m2v (1892.3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5381 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 49:09 minutes - 70728 frames
Wavi+Aften Parameters: "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_Title_02_4. The Thing in the Pit_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit_1.ac3"
<3/30/2011 5:38:45 PM>
Created File: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit_1.ac3 (189.6 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 59:09 minutes
BatchMux Parameters: -arglist "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_BatchMux.ini"
BatchMux ini file:
-mxp "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_MuxMan.mxp"
-l "C:\DOCUME~1\LOCALS~1\Temp\DVD_0_MuxMan.log"
-prio LOW
-v "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends_1.ac3"
-a1lang en
-cellfr "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends_Chapters.txt"
-progfr "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends_Chapters.txt"
-chapfr "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_01_3. Legends_Chapters.txt"
-SEG2v "C:\Documents and Settings\\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit_1.ac3"
-SEG2a1lang en
-SEG2cellfr "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit_Chapters.txt"
-SEG2progfr "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit_Chapters.txt"
-SEG2chapfr "C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0_Title_02_4. The Thing in the Pit_Chapters.txt"
<3/30/2011 5:53:08 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 4442.7 MB
vs Estimated Size: 4449 MB -> 0.1% undersize
vs Assets Size: 4414.2 MB -> OK
Created Folder: C:\Documents and Settings\My Documents\Videos\convert_x\DVD_0 (4442.7 MB)
<3/30/2011 5:53:11 PM>
Thanks MR.C! Appreciate the help. I'm back on track with your program, and enjoying it as usual.
@davexnet
Weird.... I dunno... You guys are much better at this than I, and have helped me to get it working.
Thanks for the info on gdsmux, I'll check it out. I used mediastreamclip (I think that's the name) before, and it allowed me to basically change extensions sans transcode. Does gdsmux do the same (I'll check in a min but still value a response such as yours, concerning it's ability with m2ts) ???
I haven't played with that yet... Every new program brings a little more knowledge.
Thanks again.
newbtube - as I recall, add the m2ts on the input tab, and deselect "minimize output size" on the global options.
Then hit start, and it will create the MKV.
AVSTODVD avi to dvd audio sync problem
By stem300 in forum Authoring (DVD)Replies: 6Last Post: 26th Dec 2011, 13:52 -
AVStoDVD Audio sync (m2ts source)
By newbtube in forum Video ConversionReplies: 10Last Post: 5th May 2011, 22:57 -
Problems converting m2ts with subs in AVStoDVD
By eon_designs in forum Blu-ray RippingReplies: 6Last Post: 12th Dec 2009, 07:03 -
sudden vdub sync problems when converting hd sources
By uk_dan2k in forum Newbie / General discussionsReplies: 10Last Post: 8th Feb 2008, 16:37
), worked great, and has given me much more options without a new program to download. Appreciated...
