  1. Hi Friends,
    I have been burning ripped DVDs for a while now. Recently I cam acroos a weird problem, I burned a ripped DVD9 using XP/Nero9 Express/Sony DVD Writer. It plays in my PC(PowerDVD9) but doesn't play in my Philips HTS3571, It says No Disc. First copy i burned was wasted as It just shown starting screen in PC but won't go furtehr and My DVD won't recognise it. In second copy above mentioned problem.What cud be the problem? What should I do? ( A Lot of DVD I burned are working fine).
    In another DVD5 I burned works like a charm with PowerDVD9 but playback in DVD player just doesn't work, keeps freezing, plays like x32 FF, will show a frame for 2-3 sec nad the another frame, and like that.
    Will be gratefull if anybody can tell what to do?
    Oct 2005
    666th portal
    bad discs? about the only worthwhile ones are taiyo yuden or verbatim +r dl. as for burning you should only use imgburn, it's the best and also free.
  3. Originally Posted by aedipuss View Post
    Thanxx, Mate, Wud try Imgburn and get back.
  4. Imgburn didn't help. Disc doesn't verify, I t doesn't even play with PC.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Then try a different brand of blank discs and see if you get the same issues. If different discs have the same problem it could be your burner is dying.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by lauraman View Post
    this could be problem with disc. Use + discs because some players have problem with reading - discs.
    wrong.
    Nov 2009
    Germany
    Try once again with ImgBurn at max. 4x speed.
    ggtop
