If I rip an episode from an apisodic dvd, using either PGCDemux or MakeMKV, after encoding that rip with StaxRip to .h264, and mux it with the ac3 to mkv, then that mkv, at playback time, the video frames play faster than normal and than the audio, and it ends a couple of minutes earlier than the audio. If I rip the episode with DVDfab or DVD Decrypter, after encoding, the video has normal speed, of 29.97 fps. But I can't use DVDfab or DVD Decrypter because they do not properly rip the episode
solved !
stax76 from doom10 forum knows about this "Wrong Source Framerate in StaxRip" issue. His solution is to manually change the video frame rate by appending the following code in the avisynth script:
LE:AssumeFPS(30000,1001)
not solved! after appending that line of code, specifying the correct source fps, the encoded file still has a different fps than source
but at least you can open both episodes (vobs inside one VTS) in StaxRip, without having to extract each episode from that VTS, and select only the frames containing one episode.Last edited by codemaster; 22nd Mar 2011 at 22:26.
virtualdub: input video distorted on 32 bit but not 64 bit
By iggogg in forum EditingReplies: 18Last Post: 5th Oct 2011, 02:34 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
Please share with me how I can get videos to play faster?
By karbear in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 18:50 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 16:44 -
make a video play x1.3 or x1.5 faster
By tomchook in forum Newbie / General discussionsReplies: 3Last Post: 9th Jun 2008, 01:53
