Hi all. I ripped a DVD using DVD Shrink. The file size is 4.46gb.
I currently do not have a dual layer dvd burner. Is there any other way for me to burn this without having to purchase a new burner?
Thanks!!!![]()
No. Shrink again or remove some extras or cut it with dvd shrink.
Thanks for your response Baldrick.
I would like to keep everything in tact on the disc (including extras). Should I Shrink again with a custom ratio under compression setting? -
Usually there are several language streams, each a few hundred MB. If you just keep the one(s) you need you can probably fit the video unaltered.
You can also delete unneeded subtitles, though these are only a few MB each; but it simplifies playing the DVD.
And often the "Extras" includes previews of other movies, FBI piracy harangues, these are pretty disposable. -
What hech54 said plus I'd like to point out that the original poster said only that he "ripped" the disc using DVD Shrink and based on that alone we have no way to know if he actually shrank it or not.
xxxjojoxxx - You need to be aware that DVD Shrink cannot correctly rip all current DVDs. It was abandoned years ago when its author was hired by Nero. If you use it enough as a ripper you may eventually encounter problems.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
