I regularly burn AVI files direct to DVD as data files - our DVD player will read these and play the AVI quite happily. It allows me to get lots more video onto a DVD than if I changed the AVIs into DVD format first. But I've recently got a few AVIs that play fine on my laptop or my desktop - but when I burn them to DVD, they don't play properly on my DVD player. The sound works fine, but the video doesn't - It will show a frame (while the audio is going fine in the background) for 5-10 seconds, then leap to another frame, then show that one for a while, then a new frame, and so on. So I basically get one frame every 5-15 seconds of video. It's not a bad DVD (because other AVIs on the same DVD play fine), and it's not a bad burn (because I've re-burned the files a couple of times, and they're always the same). Anyone got any idea why this is? And what I can do to fix it so the AVIs play happily after being burned to DVD as data files? Thanks for any help.
Results 1 to 9 of 9
Just to clarify, the size of the avi is really irrelevant, its the running time that matters. If you have a single movie that is 4GB in size then that's one thing. If you have 6 of those 700MB DVD Rips (about 4 GB worth) and try to cram all 12 hours onto one DVD with dvdflick the output will be hideous....... Just do what Baldrick said and run it through avirecomp.
As always, if you're playing AVI files on your standalone and you have a problem, look at the avi file with Mediainfo.
XVID encoding options such as QPEL and GMC are not handled well by the majority of players.
Compare a working with a non-working file if necessary. -
When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
I would assume so, since it's the capabilities of the decoding chip within the player that's the issue.
I did what you suggested, and I found a difference in the QPel and GMC settings:
Working: QPel: No
Not Working: Qpel: Yes
Working: GMC: No warppoints
Not Working: GMC: 3 warppoints
So from what you say, that sounds like it might be the problem - so thanks a lot for your help.
The question now is - how do I fix it? -
If you want to play it on your standalone, you have to re-encode it.
Corrupt AVI, 14 seconds viewable in VirtualDubmod.. but...
By DVDer27 in forum RestorationReplies: 6Last Post: 1st Jan 2011, 03:18 -
Burning a AVI file to dvd
By tim_ver in forum Newbie / General discussionsReplies: 14Last Post: 7th Dec 2008, 08:05 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 07:40 -
multiple .avi files on a DVD-R that is viewable on a standard DVD player
By ottawadave in forum Video ConversionReplies: 8Last Post: 18th Jul 2007, 12:32 -
AVI to DVD Burning
By DVDHelpPlease in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 00:38
