Page 2 of 2
FirstFirst 1 2
Results 31 to 37 of 37
  1. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    state the model of motherboard.....what chipset controller for the IDE is it using? Intel? Via? Nvidia? It does make a difference when it comes to optical drives. Also if you're using the ide cable that came with the pc/mobo buy a new one anyway......just my 2 cents!
  2. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Please find Pdf file attached
    Image Attached Thumbnails ASUS_p5g41c-m lx.pdf
  3. Less than meets the eye. Phlexor's Avatar
    Jun 2001
    Victoria, Australia
    You say you are using a new 80 wire IDE cable but also talk of jumpering your drives Mater/Slave. Why are you not using Cable Select?
    Feb 2004
    Australia
    This might be caused by windows 7 retarded AHCI driver.
    Link > Choose either 32bit or 64bit ... extract to usb flash drive
    Then from a new install
    1: Chose "custom install" only
    Under the screen that shows you the drives and where you want to install Win 7, there is a small check box (should be on left side below drive screen). Check it.
    2: Select the Intel AHCI driver on the USB drive
    3: Continue till completed
    However ... still need to sort that "no spin" drive issue before hand and make sure bios see's it.
  5. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Thanks Bjs. I'll try that. I downloaded STOR_all64_f6flpy_9.5.0.1037_PV.zip. Just waiting delivery of new LG optical drive.
    Please give me a couple of days. I'll let you know how it goes.
    John
  6. You're right, a functioning device that shows no indication of power on a new build is nothing at all to worry about.
    By all means follow the advice you have been getting from folks that know absolutely nothing about your PC and your situation.
    Good luck to you, I am done here.
  7. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Success at last.After installing new Lg SATA optical drive and new Corsair 600 W PSU Windows 7 installed successfully.
    Thanks to everyone that help me.
    Regards
    John
