Hi ...I'm using Windows XP Pro SP3 . I'm trying to play blu ray movies on my computer . I went and bought the LG BD-ROM/DVD Rewriter OEM model #UH10LS20 . In the Devise Manager area I see DVD/CD ROM drive >>> HL-DT-ST BD-RE UH10LS20 . Under My Computer whenever I put a bought blu ray movie I see it change to cd drive and nothing appears . I don't get to see anything at all . Now I have the CyberLink PowerDVD 10 Ultra 3D software and I can play the blu ray movie with it but I still don't see anything at all from my optical drive. It doesn't show any blu ray disc from my optical drive . Is their some sore decoder I need to be able to see my blu ray disc ? What am I doing wrong here people ? Pls help , thanks
Xp has no native read support for UFD 2.5 as listed by the wikipedia ... which is why when you use windows explorer to view the contents of such discs nothing is shown ... vista and up include native support for UDF 2.5.
The utility linked by fritzi93 should solve that particular issue. -
Hi ... Okay , I downloaded that zip file and open it with Winrar but I don't have the option with Winrar to install once I right click on .inf extention . So now what to do ? I try double clicking on it but I didn't notice anything getting install after I rebooted . I did see it say something about Toshiba driver but I am still at the same problem as from the beginning ...
Extract all the files to a folder on your hard drive then right click on the inf file in that folder.
Perfect , Thank you so much . This time I was able to see install option and it did the trick ...
Wow Thanks for your posting this problem as I am having the exact same problem.
I brought a new 3D LCD TV last week, and I wanted to copy some Blueray disks to use on it. So I went to the local swap meet and brought a new LG BH14NS40 for seventy dollars, took it home plug it in to my Windows XP service Pack 3 operating system, and it could see CD'S OK, then DVD'S OK, but as soon as I put in a Blue Ray Disk the computer thought it was a CD disk and gave me a blank screen.
So I took it straight back and swapped it over with another unit., got home and same problem. I then rang LG Service line and they could not help me at all.
So there I was in a HOLE!!! swearing away at this disk drive.
The I googled the problem and your mesage came up, so I downloaded the UDFReader and loaded it, then reboot and WAM!!! IT NOW WORKES.
So why don't LG bundle this software with the drive and save us all a lot of trouble.
So again thank you for your posting................ -
Aussy777 - I'm glad you got helped, but please don't post "thanks" just because you got helped. If everybody that, some of our threads would have hundreds of posts that said "thanks". We're glad to help, but we don't need a post from you if you got helped.
For unknown reasons Microsoft decided not to officially support the UDF versions above 2.00 in XP. This is why XP systems need to install UDFReader or they will have problems playing BluRay discs. BluRay uses UDF version 2.50. Vista and above support UDF 2.50. Perhaps Microsoft left out official support to try to encourage people to upgrade from XP.
DVD recorder doesn't show colours
By mireille in forum Newbie / General discussionsReplies: 8Last Post: 2nd Nov 2010, 06:08 -
DVD-ROM doesn´t read DVD
By jsilv in forum DVD RippingReplies: 11Last Post: 7th Mar 2010, 06:43 -
DVD Menu doesn't show
By miki22 in forum Authoring (DVD)Replies: 1Last Post: 19th Mar 2009, 17:17 -
My computer doesn't read dvd+rw disk
By jayjayj2 in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2008, 12:05 -
Video TS folder doesn't show up after DL.
By crowheart in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2007, 10:56
