can someone recommend or point me in the right direction for taking a german tv show in mkf format, strip the audio and reattached an english audio stream ripped from the true dvds. might be tricky since they are tv rips and not actual dvd rips.
thanks
Use mkvtoolnix to add/remove audio from mkvs and pgcdemux for dvds.
But you probably have to manually resync the audio. -
Yes but for mkvs mkvtoolnix will remux any audio into the mkv while mkvextractgui2 (needs to be in mkvtoolnix direcctory)will extract the audio from a mkv and pgcdemux only extracts audio, video,chapter,subtitles from dvd's, it doesn't remux them.
thanks guys. i was more worried about manually adding the new audio track. aftert thinking about it, it may be alot more work than i really want to do since the source is a tv rip i'll have to do alot of splicing of the audio.
Swapping M2TS files from Encore authored Blu-ray
By fxtm in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Apr 2012, 05:46 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
No audio in MKV files when using MPC.
By ohnoeee in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2011, 03:04 -
MKV Playback Recommendations
By Khalua in forum Software PlayingReplies: 1Last Post: 7th Apr 2010, 13:11 -
Swapping the Audio Streams in a MKV in order to then convert
By JP585 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2008, 04:26
