I recently had to change out my graphics card and restart Windows XP Pro. Now my DV files won't play smoothly or without scan lines. In WMP, they won't even play in the right aspect ratio. They used to play perfectly and were my favorite file type to watch and edit from. I have tried many codecs, including the MainConcept codec they were created with. I must be missing something right under my nose, but I'm stumped.
Any suggestions? I miss being able to use and enjoy those files.
Thanks!
Results 1 to 30 of 53
I just now tried the Classic Player - exact same results.
The card is a Radeon HD-6850. Should be enough to play a DV clip. -
It succeeded in registering, but no change in playback. I'm still trying to find updated drivers for my graphics card. So far, all I get is B.S. little 'helpers' and password-protected .rar files. None seem to be legitimate.
I hate to double-post, but I just updated the drivers and still get the same result.
Arrrgh.
time for a c: drive format and re-install windows from scratch.
This is a fresh install. No errors or bottlenecks were encountered throughout the process. The install is only about a week old or so. I had an nVidia 8800GTX card which went sour. I bought the new card and performed a fresh install of XP Pro with the new card.
Get the latest WHQL certified drivers directly from AMD.
http://support.amd.com/us/gpudownload/Pages/index.aspx
DV should play in XP SP1 or newer without installing any codecs (though you should update to SP3 anyway). The DV codec that comes with windows will automatically bob deinterlace in WMP. What graphics card you use has nothing to do with it.Last edited by jagabo; 21st Mar 2011 at 18:14.
sorry to hear it. no codec packs or other crapware installed? dv is about as easy as it gets for a computer to play. bad video card maybe? never used a amd/ati video card here, i avoid them like the plague.
Since you have MPC, play one of your DV AVI files with it. While playing, right click on its video window and hover over Filters... That will show you the list of filters that are in use. You can select any of them to set any available options and to get more information about them. Also, from the main MPC window you can select View -> Options -> Internal Filters. You can then switch its internal AVI Source Filter off or on. Try changing it's state and see if what works better. You have to exit MPC and restart it for changes to take effect.
If you install GraphStudio you can drag a DV AVI file onto it and it will build a DirectShow Filter Graph, the same thing WMP does when it plays a file. You can then right click on any of the filters to get information and select options.Last edited by jagabo; 24th Mar 2011 at 07:24.
I have since restarted Windows XP. I installed the new video card with everything updated and the whole nine yards. My players still play all files and formats like before and yes, the DV is still screwed up. It's kind of funny. I have not clue #1 regarding what went wrong.
I reinstalled XP.
I installed no codec packs and I tested the playing of DV files along the way after I installed. -
Try running mplayer2.exe. That's WMP 6.4, still included with newer WMP releases. You can find it in:
C:\Program Files\Windows Media Player\mplayer2.exe
Does it have the same problem with your DV AVI files? If so, right click on the player window and select Properties. From the properties dialog select the Advanced tab. That will show you the list of filters that are being used to play that video. You can view the Properties of any of those filters to change internal settings. See if you can get a proper display by changing the settings. Especially the DV decoder and renderer. -
I did as you said to no avail. Nothing seems to affect the scan lines. I guess I might just have to live with it, even though it's annoying me to no end. I can't see it as being a hardware problem; all the other clips and file types work just like before.
Thank you so much for your help, guys.
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 13:10 -
.avi files that won't work correctly!
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 17:41 -
Windows Media Player Won't Play DVDs Anymore
By Card Shark in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2010, 19:04 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 15:57 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 17:44
