First off, I just want to say I'm sorry if I put this in the wrong forum; I have no clue where this question should go.
I have this device.... All it is is a black box with a power supply. It has an F-connector input, an F-connector output, and a power supply jack.
There are no buttons, no switches, and no labels. The only thing I see is a sticker on the bottom labeling the input/output and a stamp that says "FTG-RF"
The power supply says Texas Instruments though I'm not sure it is the one that came with the device (it says on the power supply "For use with calculator")
I would post a picture but like I said, all it is is a metal box. I'll post a picture anyway if it will help.
Any ideas what this device is or could be?
Results 1 to 12 of 12
Ohh that makes sense. Also explains the power adapter.
Judging by the F connectors, I assume that means these would have been used with VCRs. Do you think these would work with DVD players if I got an RF-RCA adapter? -
I would have said an RF amplifier: http://www.amazon.com/Magnavox-M61107-out-12-Amplifier/dp/B00006JQ9V/
Ok, I'm convinced this is probably an amplifier. Definitely no RCA jacks and battery components. However, most of the amplifiers I'm seeing seem to have 3 RF jacks, not 2 like mine does.
I wish I could find some info on the exact one I have. Running a search of both macrovision devices and of RF amplifiers have been unsuccessful as i have not seen the one I have yet.
I'll just have to keep looking. Are there any other possibilities on what this thing could be? -
Are there any identifying numbers or characters on it, like a serial# or something you could enter in a google search?
Dare, there's really nothing. It's really making me wonder if it's the Black Box due to the lack of detail.
The sticker says FTG-RF and running a search of that gives hundreds of unrelated results.
I tried searching the model numbers of the power plug to see if it matches something but no luck. It's showing me Texas Instruments chargers but not what devices might have been shipped with those chargers. I searched TI amplifiers and all I see are chips, not boxes like what I have.
I could always open it and see if there's any information on the chipsets but I'd hate to do that and risk damaging a perfectly good advice. It always makes me more nervous opening things that are dangerous when near magnets (I'm Deaf and I have a cochlear implant, which means I have a magnet in my head) -
Sounds a lot like one of those cheater box a.k.a black box for unlocking PPV and movie channels on analog cable. Useless with digital cable.
You need better Google-fu.
http://forum.ecoustics.com/bbs/messages/2/140183.html
Judging from that thread, it's an illegal cable decoder black box like 47nic2k4 suggested."I can wire anything directly into anything!" - Professor Farnsworth -
Correct, that's the third search result in:
http://www.google.com/search?num=20&hl=en&safe=off&q=%22FTG-RF%22+%22black+box%22&btnG=Search
Yep.Judging from that thread, it's an illegal cable decoder black box like 47nic2k4 suggested. -
Wow, you're right, I really need to work on my searching. Sorry about that but thanks!
When I got this box, it certainly didn't come with a second device, so this is probably useless to me. Oh well.
Thanks everyone for your help!
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Question about new Power supply ?
By VEBouto in forum ComputerReplies: 7Last Post: 8th Oct 2010, 15:36 -
How do you test a power supply?
By ricoman in forum ComputerReplies: 3Last Post: 4th Oct 2010, 13:54 -
Slightly OT -- Power Supply for External USB HDD used with Portable Device
By GrayStrickland in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 15:50 -
fixing an old TV (power supply)
By moviegeek71 in forum Newbie / General discussionsReplies: 21Last Post: 16th Oct 2008, 15:58
