Hi all,
I'm having trouble with using multiAVCHD to burn a multi-title DVD out of some AVCHD (.TS) files. Everything works fine, including transcoding for SD-DVD, except that the two titles come out as separate DVDs, with no menus anywhere. The menu preview works, and I've tried uninstalling and reinstalling the program to reset its defaults in case I checked something unusual. The only settings I've changed from the default are:
* Force [D]AR to 16:9
* Create top menu
* Setting a custom background image
Does anyone have any advice? Thanks!
To clarify, out of the three things I've changed from the default, the top two are check-boxes and the bottom one is specifying a file that is a 1920x1080 .JPG.
Update: using the default background instead of a custom one doesn't fix the problem.
Cannot get multiavchd to create menu
By Yanta in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Feb 2012, 23:29 -
How do you do main movie hd-dvd to avchd in multiavchd with 2+ audio tracks
By yoda313 in forum Video ConversionReplies: 2Last Post: 27th Sep 2010, 20:18 -
multiavchd, create menu?
By volam1 in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jul 2010, 13:31 -
How can I create this very simple menu with Multiavchd?
By alc112 in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jul 2010, 13:26 -
Create DVD with selectable data file within main menu, help?
By Distearth in forum Authoring (DVD)Replies: 1Last Post: 2nd Jan 2010, 17:45
