    May 2008
    I hope this is the right place to post this issue.
    I usually use DVD Flick to convert mkv movies to DVD5 for the grandkids . The default size of the target file in the program is 4.3G which is what I always use. However with this one movie the resultant file size came up to be 4.8G ( very surprising) so obviously it cannot be burnt to DVDR. This has never happened before . The only way for me to fix this was to select a custom target file size of 4G . The converted file size then came out as 4.29G . Any idea why this is happening? Tks
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just run the over sized one through DVDShrink.
    May 2008
    Just wondering why it is oversized to begin with.
    It might identify the source runtime/length incorrect(too low value).
