    Feb 2002
    Canada
    Hi.
    What is the bit rate for Firewire cards?
    Do Firewire cards have different bit rates?
    Thank you.
    Jenny
  2. The maximum data transfer rate for the Firewire/1394 bus is 400Mb/s (Megabits per second) or 50MB/s (Megabytes per second).
    However I think you are asking about the bitrate of DV video over Firewire/1394, which is about 25Mb/s or 3.6MB/s. DV doesn't use the full bandwidth capacity of Firewire/1394.
    All Firewire cards are theoretically capable of the 400Mb/s maximum, but some cards are more compatible with certain cameras and other peripherals, and some cards perform better than others. In general the TI (Texas Instruments) chipset-based cards such as the ADS Pyro and others are a good choice.
    Feb 2002
    Canada
    Hi.
    Thanks JHebert.
    It's funny you mentioned the ADS Pyro. I was looking in to getting that.
    ADS is part of Texas Instruments?
    Jenny
