Hi Sir..
I recorded some important videos from a VHS with Snazio Tv Tuner Card's a/v in option. The software was Intervideo WinDVR 3.0 and in the format section I set video to mpeg2 720x576 with 3000kbs bitrate and audio to 48khz LPCM. Now after i captured, I tried to play it in first the windvr itself, then in jetaudio 7, then in PowerDvD and also tried in KMPLayer and Media Player Classic as well..Am getting same problem everywhere which is AM Unable to listen to audio at all.. No program gave an error message and when i check properties of recorded clip in any program it does show that it has audio like PowerDvD shows information of audio LPCM 2.0 1536kbs with video as mpeg2 3.02mbps Plz guide as how to listen to its audio. already installed are codecs of k-lite mega pack. Captured File sizes are normal too..as they used to be earlier.. no new hardware added nor windows re-installed. Its fujitso-siemens esprimo 3.0 with 4gb ram.
Regards
I suspect you had the wrong audio input selected when you captured the video and hence recorded silence. Open the audio in an editor and look at the waveform. You'll probably see two flat lines. Try VirtualDub:
1) File -> Open Video File (select your MPG file)
2) View -> Audio Display.
3) Scrub through the video and watch the audio waveform.
Video Compression - Urgent Help needed!
By dberm22 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2011, 10:37 -
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
Urgent Help needed: all video converters corrupt my mp4 files, accelerating
By marilia05 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2011, 05:50 -
Urgent help needed pls. converting mp4 to xvid- cant get sound
By prendersparty in forum ffmpegX general discussionReplies: 4Last Post: 14th Sep 2010, 13:35 -
urgent - advice needed! date stamp
By devdev in forum Capturing and VCRReplies: 3Last Post: 22nd Jul 2010, 16:53
