Dear all
I'm trying to convert a short video with Avidemux 2.5.4 from a mp4 container to a mkv container (save space by reencoding it). However, this video, like many others I've done (and faced the same problem), causes a delay in the end converted video (delay of around 400 ms, but varies throughout the video).
Any ideas why this is so? Could it be the fault of 3gp4?
I'm using the settings X264 for video and copy for audio in a mkv container. I've attached the media information for the original video below:
Code:General Complete name : S:\MOV_0006.mp4 Format : MPEG-4 Format profile : 3GPP Media Release 4 Codec ID : 3gp4 File size : 25.1 MiB Duration : 34s 67ms Overall bit rate : 6 184 Kbps Law rating : (empty) Released date : 0 Classification : (empty) Video ID : 1 Format : MPEG-4 Visual Format profile : Simple@L6 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : 20 Duration : 34s 67ms Bit rate mode : Constant Bit rate : 6 000 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 15.264 fps Minimum frame rate : 8.772 fps Maximum frame rate : 18.519 fps Color space : YUV Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.427 Stream size : 24.8 MiB (99%) Language : English Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 34s 64ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 16.0 KHz Compression mode : Lossy Stream size : 273 KiB (1%) Language : English
is probably the cause. But try xmedia recode. -
Perhaps try the Avidemux proxy. Possibly directshowsource with Haali's directshowsource2 selected.
Needs a few plugins in the Avisynth folder, but it's detailed here:
http://avidemux.org/admForum/viewtopic.php?id=4397 -
Hi,
I am experiencing a similar problem. I want to take a m2ts file (VFR, ~25Gb) and mux it with an eight channel wav file (~8Gb) and then recode it to H264 Baseline Profile.
All the programs I have tried either:
1) Crash
2) Cannot handle WAV-files greather than 4Gb
3) Creates an output where audio and the movie is in sync in the beginning of the movie but almost two minutes out of sync in the end (the movie is about 1:53 hours long). I had this problem with MeGUI and AVISynth. I tried changefps, assumefps but did not find a solution. The output video always became 1:55 hours long but the audio remained 1:53 hours. I also looked at:
http://avisynth.org/mediawiki/VFR
4) Cannot handle eight channel output. Allthough some programs could not handle 7.1 audio, I still tried making the video conversion but the video typically became "jumpy" like some frames where missing or the frame rate was very low.
Can someone tell me what program I should use/how I can do the conversion without the mentioned artifacts?
/Kim
Audio/video out of sync after converting (avi to mp4)
By Foxy Gogo in forum Video ConversionReplies: 1Last Post: 10th May 2010, 13:13 -
Youtube MP4 Videos Converted to AVI Have Out-of-Sync Audio
By ConverterCrazy in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 17:31 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 22:28 -
mp4 video and separate audio completely out of sync...
By foler in forum EditingReplies: 0Last Post: 4th Mar 2009, 07:42 -
Audio out of sync with video: FLV > MP4 using ffdshow
By jk318 in forum Video ConversionReplies: 0Last Post: 16th Aug 2007, 22:07
