when I try to capture, the video freezes after 45 minutes, then will only display video (no sound) - not a big deal since it still encodes the audio. on playback, only first the 10-15 minutes are encoded. everything else looks OK - drivers are up to date
any ideas ?
The first thing that comes to mind: Where are you storing the captures? If it's an external drive formated as FAT 32, it can only do files in 4GB blocks. Check your captured filesize. If it's a bit short of 4GB, then that could be the problem. Second, does your capture drive have enough room? Running out of HDD space can cause problems.
More questions: What format are you capturing the video with? What codec? What are you capturing? TV? What software are you using for capture? Sometimes the software bundled with a card really sucks. Check around for better software that is compatible with your card.
Last, try to find a user forum for that particular card. Most times, they have already experienced the most common problems and maybe even have a solution.
Other members here may have some better information.
And welcome to our forums.
Maybe the software update from Diamond will help. http://www.diamondmm.com/VC500.php
Need help with Diamond One Touch Video Capture
By leoorl in forum Video ConversionReplies: 3Last Post: 28th Apr 2012, 10:11 -
VCS Diamond 7.0.29 Echoes
By Nagashi in forum AudioReplies: 0Last Post: 12th Jan 2012, 08:23 -
Diamond VStream any feedback?
By halekon in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jul 2011, 13:35 -
Diamond ATI TV Wonder HD 750 USB
By Caple in forum Capturing and VCRReplies: 4Last Post: 16th Jul 2010, 21:39 -
Diamond vision help No disc!
By cripboy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 11:49
