Basically, looking for a free program that allows me to change the volume of all tracks the same level during the burn or before burning it on the CD.
Also the audio is in rm format if that makes any difference.
Any help is greatly appreciated.
As I've said and given examples of a number of times before, Normalizing all track peaks to some set level (usually 0db) DOES NOT make all tracks SOUND the same level. That's because tracks have varying ratios of Peak-to-RMS level. You could do it that way if you want, but that probably won't get you what you really were hoping.
It would be the same as setting all videos to X Mbps bitrate to match the quality of an original track. In those cases, items with greater motion would get worse quality and items with lesser motion would get greater quality.
That's why AC3's "Dialnorm" was created, although it often gets misused.
AFAIK, there is NOTHING that has the smarts to set peak, RMS (aka average) and Peak-to-average, automatically. And you may not want to. Different kinds of music/dialog/SFX have differing dynamic range requirements. Otherwise, everything would be squeezed to sound the same, like heavily-limited FM radio stations.
Scott -
Are you sure?... Cause I usually use Realplayer to burn my CDs and and noticed in the edit options for when burning CDs, theres an option under "Audio Filters" which says 'Make volume equal across all tracks'. You need to buy the Realplayer feature to use it though which I obviously have not got...
normalizing to 0db does make all tracks as loud as they can be without clipping. nothing more or less. if you're not an audio engineer it's you're best shot.
Looking for a free tool to make a video out of still image and music
By peteman in forum Newbie / General discussionsReplies: 5Last Post: 12th Aug 2010, 15:18 -
Video Audio Volume level
By Directlinq in forum Video ConversionReplies: 2Last Post: 16th Nov 2009, 13:43 -
How do you know the volume level of each channels in a 5.1 track?
By zee944 in forum AudioReplies: 2Last Post: 7th Sep 2009, 10:54 -
Is there any real value to "5 free music tracks from MyMusic for EDIUS
By TBoneit in forum Off topicReplies: 1Last Post: 22nd Jul 2009, 11:13 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 19:15
