    Jan 2011
    poland
    original source is from HD PVR (*.ts) recorded from tv (1080i50) - MTV nHD.
    What I describe below is my own approach and it may be 100% wrong as I do not know too much about it.
    After recording when I play back the file I got the information that it is 25 fps and interlaced - thats correct.
    But I noticed that some music videos played on MTV nHD are not interlaced (2 fields responsible for frame are almost identical and don't create "comb" effect at all) - I checked i t with avisynth separatefield() command.
    Since my goal is to make this music play on my portable pmp (cowon q5) I have to convert it to xVid - resolution 800x448.
    And since these fields are almost identical I decided to do this as follows:
    DirectShowSource("e:\_libs\Videos\_tv\_alexisJorda n_goodGirl.ts")
    assumeTFF()
    separateFields()
    selectOdd()
    crop(8,4,-0,-4)
    Spline64Resize(800,448)
    and when I play the resulting clip on my computer everything is fine but when playing on pmp audio is delayed.
    Jan 2011
    poland
    small correction (I tried these conversions so many times that I alredy lost myself
    there is no a/v sync problems on my pmp only if I convert songs which were recorded in 720p (set on satelite tuner) - then I get 50fps progressive and this material I can convert with following script:
    crop(8,4,-0,-4)
    and pmp plays fine - no a/v delay
    I got problems (a/v delay) when converting from 1080i (set on sat tuner).
    Playing after convertion in vDub there's small a/v delay even on my computer - but on pmp the delay is much greater.
    Jan 2011
    poland
    never mind.
    I used vDub + filters directly (no avisynth's scripts) and there's no a/v delay anymore.
    Jan 2011
    poland
    no... it's still not right...
    could anybody take a look at the file in attachment - it is 16 sec long video which I cut using videoRedo
    I need it as xvid:
    video: 800x448, 25 fps, bitrate <= 4000,
    audio: 48kHz, ac3, 2 channels, max 196 kb
    whatever I do (convert) audio is always delayed when I play on my pmp.
    Thank You very much for any help.
