Hello guys,
I been recording some HD movies from ProgDVB, and been trying to split them , the regular (not HD) recorded films they split fine.. but I am having problem splitting the HD files I recorded.. I was using Avidemux for splitting without re encoding! but when I try to open through this program it open very very slow! and I cant seek through the file!! and a weird thing ,, the 3 or 4 minutes HD files I record appears on the MPC 22 minutes or something!
any help please?
here is the text file of the info of a random HD file I have..
.. Thanks a lot
General
Complete name : C:\Video Center\MTVNHD - March 19 16 24 17.mpg
Format : MPEG-PS
File size : 747 MiB
Duration : 9mn 26s
Overall bit rate : 11.1 Mbps
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 9mn 25s
Bit rate : 10.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.197
Stream size : 688 MiB (92%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 9mn 26s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -34ms
Stream size : 17.3 MiB (2%)
Audio #2
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 9mn 26s
Bit rate : 384 Kbps
Bit depth : 16 bits
Delay relative to video : -22ms
Stream size : 25.9 MiB (3%)
DVB Subtitles in Mpeg TS
By casuva in forum SubtitleReplies: 7Last Post: 30th Nov 2012, 04:19 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 06:38 -
HDTV recordings: 1920x1088 vs. 1920x1080 lines.. [SOLVED]
By vhelp in forum DVB / IPTVReplies: 47Last Post: 27th Oct 2008, 19:16 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 12:11 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 08:02
