I'm trying to convert an mkv to play on the ps3 but it just won't work.
I've tried using Xvid4PSP and i get the error " FFmpegSource: Couldn't open C:\Documents and Settings\Tyler\My Documents\Downloads\Tron:Legacy.2010.BluRay.1080p. DTS.x264-CHD.mkv" right after it demuxes the audio.
And I've tried using mkv2vob but it doesnt' even want to accept the file to start it.
Code:Format : Matroska File size : 13.1 GiB Duration : 2h 5mn Overall bit rate : 14.9 Mbps Encoded date : UTC 2011-03-19 05:36:10 Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Muxing mode : Header stripping Codec ID : V_MPEG4/ISO/AVC Duration : 2h 5mn Bit rate : 14.6 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.294 Stream size : 12.8 GiB (98%) Title : Tron.Legacy.2010 Language : English Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Muxing mode : Header stripping Codec ID : A_DTS Bit rate mode : Constant Bit rate : 32.0 Kbps Channel(s) : 1 channel Channel positions : Mono Sampling rate : 0 Bit depth : 16 bits Compression mode : Lossy Title : DTS-CORE 1536K Language : English
Closed Thread
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
.ts to .mkv problem?
By jiopi in forum Video ConversionReplies: 2Last Post: 30th Sep 2010, 07:23 -
.TS To .MKV Problem
By PsyChoses in forum Video ConversionReplies: 0Last Post: 29th Nov 2009, 17:43 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45
