English is not my first language, but I'll try and explain my problem the best I can
I bought a new hi8 cassette a couple of weeks ago because I wanted to film on a weekend I was going to spend away, and the only camera I have at the moment is a old hi8 camera. The problem is that when I watched what I have filmed, there was this loud distorted "industrial" sound that came in the beginning of each new take. At first it slowly faded away after a few seconds and then you could hear normal sounds. But after a while the sound lasted longer and longer until it became constant. I have to scream into the mic to hear my voice over the distortion, and even then you can barley hear what I'm screaming.
I'm a newbie when it comes to cameras but I guess there is a problem with the record head (A hi8 camcordes does have a record head yes?) Because when I connect the camera to my TV and use it as a passthrough the audio is fine. It also has no audio problems when I playback old tapes.
this may sound like a dumb question but could it help if I used a cleaning tape in record mode? or would that damage things even more?
Is there something I can do or is it busted?
btw there is no problems with the picture, just the audio
A cleaning tape might help.
But the Hi8 format records audio as AFM as part of the video signal, not as a separate track. So it doesn't make sense that video would be ok but not the audio. This points to a problem with the camcorder itself, not the format. You might try an external mic if the camcorder has a jack.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
will there be any difference if I use the cleaning tape in play or in rec mode?
I think I used to have a old mic some where. I'll see if I can find it
I went to the store today and bought a new tape just to see if the tape was the problem, it wasn't
actually I was wrong when I first said it was just the sound that was the problem. everything was in black and white now. but the color would get back after some minutes with filming. the first minutes there was a grey picture with two vertical stripes of yellow and two vertical stripes of blue and then suddently there was full color(but no sound), but when I stopped and continued filming again it was black and white again.
but playback of the old tapes that was recorded in the 90's is still ok. no problems with either sound or picture
I also tried a cleaning tape and pressed record. but the tape would just stop -
cleaning tapes work by pressing play.
If old tapes play, it would seem the problem is on the record electronics side.
That is the best kind of failure because you can still play the old tapes.Recommends: Kiva.org - Loans that change lives.
Capturing Hi8 video using Sony TRV320E D8 (PAL) camcorder distorted audio
By lchiu7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Sep 2011, 17:39 -
Q3 camcorder audio level in recording is lousy
By abrand88 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 13:08 -
No audio capture from Hi8 camcorder to PC
By dimtechno in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2009, 16:50 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26
