    Jun 2007
    Netherlands
    One of my friend gave me his laptop, which is in Dutch.
    Due to my business nature, i have to change the language of the system.
    If I change language sitting from control panel>Regional time and language, it does not change
    Any help.
    Thanks.
    Please try use a more descriptive thread title. I changed both your threads.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You can't just change languages on XP. Only Windows Vista Ultimate and Windows 7 Ultimate(the expensive ones) allow you to change languages.
    Jun 2007
    Netherlands
    Sorry modreator,
    and thanks for the help.
    Jun 2007
    Netherlands
    Thanks, i will try to install win 7 also in my laptop.
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Yes you can. I set up XP Pro in English and after it's all working I might change it to Chinese.
    See http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/int_pr_....mspx?mfr=true
    However; you need the "Windows Multilingual User Interface Pack".
    And that's not sold retail.
    But you might find it online.
    But I believe that only works if the installed language is English; then you can add other languages, but not vice-versa.
    So the answer in the original poster's case is probably no.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Windows 7 ULTIMATE you mean....right?
