This has absolutely nothing to do with VCD's but... my ATX power supply is dying a slow death and I need to replace it. Can anyone recommend a good quality (good price) 300W supply? I have an AMD 1700+ with K7S5A mb plus various accessories. Thanks!
:P
with the world getting bigger and better i have to recommend you reconsider WHY your power supply is going away slowly.
it is probably because you have too much stuff running off of it and i recommend you go for a 400watt supply. it will cost you a little more but you won't be disappointed with the increase in power available.
also the bigger supply will tend to not allow fluctuations in the supply voltage and maintain a cleaner voltage for your machine. which in turn should make your components last longer.
make the right decision ...... go big or go home. -
Couldn't agree more--bought a 400W future power dual fan supply. I must say buying a new power supply isn't as nearly as much fun as buying more ram or a new cpu--it has absolutley no bragging potential :P
thanks for the feedback though!
How do you test a power supply?
By ricoman in forum ComputerReplies: 3Last Post: 4th Oct 2010, 13:54 -
Need to choose a power supply
By neworldman in forum ComputerReplies: 4Last Post: 4th Aug 2010, 08:26 -
Power supply problem?
By Ai Haibara in forum ComputerReplies: 17Last Post: 22nd Oct 2008, 13:54 -
fixing an old TV (power supply)
By moviegeek71 in forum Newbie / General discussionsReplies: 21Last Post: 16th Oct 2008, 15:58 -
Power Supply Test
By mysts in forum ComputerReplies: 4Last Post: 3rd Jul 2008, 21:15
