  1. Hi
    Does anyone know if there is a software or plugin for Vdub that will give a great frame capture from a video by using a few frames before and a few frames after, to interpolate a better frame grab?
  2. If there's little motion you can use Temporal Smoother to reduce noise. If you're looking for a super resolution filter I'm not aware of any.
    http://en.wikipedia.org/wiki/Super-resolution
    You might try Video Enhancer.
    http://www.infognition.com/VideoEnhancer/
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by schematic2 View Post
    Hi
    The only ones I 've seen are simple frame averager programs that rely on low motion. Like those like those used for astronomy since the 70's.
    http://www.kiva.org/about
