  1. Hello,
    After finally getting BDRebuilder to work, I'm going to have a look at multiAVCHD.
    Can anyone point me to the installation requirements to make this set-up work correctly?
    I've looked at the support pages on here for this program, but other than ' this program relies on the following .....' I don't see a definitive 'you will need', or you 'must have' these versions of the following frameworks (Java, dotNet etc).
    I'm running XP SP3, and there are no dotNet or (modern) Java frameworks on it. I'd rather not download everything, as without knowing what versions to get, I could run into problems with the wrong version, or conflicting versions....
    BDRebuilder had a good tutorial on what to get and the versions (the author was very prescriptive!).
    Is there anything like this for MultiAVCHD and it's dependents?
    Thanks.
  2. Ah-ha!
    MultiAVCHD has its own forum, and there is a thread that deals with my original question:
    http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
