I'm reading a new book I recently bought - How Video Works. I really needed a primer on the basics of video and this book is a decent primer.
Anyway, yesterday I read about Mpeg compression and how I frames and P and B frames work. I can't say I completely understand the process but now know about
this.
Is there any way in Sony Vegas Studio to find these I frames and P and B frames? Can these P and B frames even be shown in editing programs?
VirtualDub and VirtualDubMod will show you whether each frame is an I, B, or P frame (in the status bar at the bottom of the window, where it shows the frame number, etc.). Any MPEG decoder knows what type of frame each frame is or else it wouldn't be able to decompress the video. But that information may not be passed to the editor itself, and even if it is, the editor may not present that information to the user.
About the only time you really need to know the frame type, is when working with non-reencoding editors that only allow cuts on I frames -- Mpeg2Cut2 for example. They will usually only show you the I frames anyway. "Smart" editors will only reencode cut GOPs. Dumb editors will reencode the entire video if you make any changes, even removing one frame from the very end.
You may need to verify the GOP size on occasion. For example, DVD players have limits on the number of frames in a GOP. GSpot can show you the max GOP length.
Importing an MPEG-4 to sony vegas platinum 9
By txpredator in forum Newbie / General discussionsReplies: 0Last Post: 24th Oct 2010, 20:25 -
Sony Vegas Platinum Burning to DVD
By jwillis123 in forum Newbie / General discussionsReplies: 0Last Post: 4th Feb 2010, 08:32 -
Rendering Errors in Sony Vegas 9 Platinum
By Sedvic in forum Video ConversionReplies: 2Last Post: 20th Mar 2009, 18:07 -
Sony Vegas Studio 8 Platinum Wipes
By luigi2000 in forum EditingReplies: 2Last Post: 30th Aug 2008, 15:46 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 23:38
