I have successfully decrypted a movie to my hard drive (in a folder named Video_TS), now want to burn a backup DVD using LG burner. Nero 7 that came with burner won't let me. Nero Support says I need either Nero 10, Nero Vision or BurningROM. Downloaded free 15-day trial of Nero BurningROM this morning, but have not tried yet. Anyone have a better suggestion or will BurningROM work? Not trying to pirate, just want a backup. Thx! <Ron>
You might want to check the size of the ripped file. A regular DVD-5 holds about 4.37GB of data. Most commercial DVDs are much larger. That may be what Nero is complaining about and it wants you to re-encode it to fit. Try the freeware DVDShrink and use ImgBurn instead.
Nero is just overpriced bloatware, IMO.
You could also use a dual layer disc and most commercial rips will fit. A DVD-9 DL disc holds about 7.95GB of data.
And welcome to our forums.
Can my dvd drive burn to dual layer disk?
By HartsVideo in forum DVD & Blu-ray WritersReplies: 7Last Post: 3rd Oct 2010, 16:07 -
Need Help! Can't get my DVD to burn from my hard drive!!!!
By kallimac in forum Newbie / General discussionsReplies: 3Last Post: 29th Jan 2010, 12:53 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
How to burn a DVD from the hard drive
By webdude3 in forum DVD RippingReplies: 5Last Post: 21st Sep 2008, 19:00 -
New DVD hangs; copied to hard drive with IsoBuster but cant burn
By bernie01 in forum DVD RippingReplies: 5Last Post: 1st Aug 2007, 17:36
