I have a new capture card from AVerMedia but when I try and capture video I get a pop up window saying the CRL certificate is rovoked or missing and to update at Microsofts drmlicense update page but I get nowhere when I get there. I read on the internet that I needed to go under internet options and under the advance tab uncheck the selection "Enable memory protection to help mitigate online attacks". But under Windows 7 64 bit the item is grayed out and I'm unable to uncheck it.
How can I upgrade my CRL certificate or remove this so I can capture video?
"Enable memory protection to help mitigate online attacks". But under Windows 7 64 bit the item is grayed out and I'm unable to uncheck it. -
The Solution is very very easy.
Unhide files and folders.
Go to "C:\ProgramData\Microsoft\Windows\DRM". In DRM folder, delete all.
Reboot your PC and try update for page....Magic, it will work, no more gray option.
Update is very fast. AVER TV HD DVR working again from HDMI input.
Claudio -
Cauptain hit the nail on the head. Also worth pointing out that you have to use IE with ActiveX enabled for the MS update site to work. I don't think the other option you mentioned in the OP has anything to do with this.
Thanks everyone. Everything updated and working.
One problem I had thou was that the DRM folder didn't show in the Widnows file until I unchecked the selection "Hide System operating files (Recommended)", then the DRM file appeared and I could delete the files and upgrade. -
Finally, a fix that would work. I did have to also unchecked the selection "Hide System operating files (Recommended)", then the DRM file appeared and I could delete the files and upgrade. Thanks.
my license key, when do i get it?
By gbenyb in forum ffmpegX general discussionReplies: 1Last Post: 12th Jan 2009, 12:01 -
Need A NEW License
By infam0usxx in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 3rd Dec 2008, 09:43 -
new license key
By djspud in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Jun 2008, 03:14 -
****** You have reached your license limit.
By red-bull in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 4th Mar 2008, 04:23 -
By microbar in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Sep 2007, 18:28
