Any one who knows a MPEG-4 AVC file structure format, to enable me navigate inside the file in binary mode, reply my post. I am familiar with theory of MPEG-4 AVC techniques and H.264 standard , but knowng the technique of standard is not enough to navigate inside the binary file. I should implement my idea and so I need to navigate inside video file. I need to know what’s the header start and end symbol, frames start and end symbols and how intra prediction data placed inside I-frame bit-stream.![]()
At the moment i am trying to find out the file generation algorithm by re-engineering the codes of open source MPEG-4 softwares such as JM, X264 and FFMPEG. Its really really hard job, Millions of line of codes should be interpreted. If anyone help me , i would be very gratefull.
Why not just email the people behind those programs and discuss it with them? It would save you a lot of time and effort going through the code of all the programs, trying to find what you're looking for.
If cameras add ten pounds, why would people want to eat them? -
Thanks for your suggestion, i emailed them but they seems very busey or assume my email is spam, because no answer received.
MP4 is based on QT/MOV. Use an atom viewer to parse the segments.
Scott -
Would you please tell me about atom viewer? Please note that i dont want to play or convert the video file. I want to navigate inside the binary file. Can atom viewer!!! help me?
It's been a while, but on the Apple website there was a Quicktime utility called "Atom Viewer" or "Atom Dump" or something like that. It parses the file and shows listing of the "atoms", which is Apple-speak for the header & payload fields/chunks.
You'd have to also check with apple for a doc that explains the meaning of the various atom elements.
Video Player for MPEG-4 AVC/H.264
By wingspar in forum Software PlayingReplies: 3Last Post: 15th Jun 2011, 23:56 -
Blocking Artifacts in MPEG-4 AVC / H.264 Video
By Eva-Unit01 in forum Video ConversionReplies: 0Last Post: 28th Aug 2010, 15:36 -
MPEG-4 AVC/H.264 video codecs comparison
By DmitriyK in forum Latest Video NewsReplies: 6Last Post: 30th Jun 2010, 07:54 -
How to create the file structure of a DVD video disc?
By mrpop151 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2009, 12:51 -
Creating m2ts video and file structure for camcorders and panasonic g10 tvs
By pkitten in forum Video ConversionReplies: 6Last Post: 29th May 2009, 09:21
