  1. Member yic17's Avatar
    Oct 2005
    Los Angeles
    Can you do auto-transition or auto-audio fade in PowerDirector?
    Like in VideoStudio, when I put two clips together, it adds a transition for me automatically. And I can easily audio fade with the click of a button.
    I'm using PowerDirector only because it can output AVI and WMV HD files without audio lag which I get in VideoStudio.
    Thanks.
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Thanks.
    Yes, you can.
    Go to configuration page and select "ADD AUTOMATIC TRANSITION "
