For example, combining the main movie, the outtakes feature, and the "making of" feature into a single seamless output file that plays all three beginning to end. MP4/MKV desired but Xvid is ok too.
I have tried the recommended programs "mkvmerge" and "DVD2one" but the documentation just doesn't cover what I want to do. Is there a cookbook guide somewhere?
LJ
Results 1 to 11 of 11
Sequentially rename all of the VOB files and join them together with something like VOBMerge of VOB2MPEG first....then do your conversion.
Or this method:
http://members.dodo.net.au/~jimmalenko/test.htm -
Without a menu, try dvdshrink
https://www.videohelp.com/guides/how-to-add-multiple-movies-titles-to-one-dvd-using-dvd...rink-id538#538
(Hint: Leave the compression set to 100%)
With a menu, try avstodvd -
My test DVD has five titles, the two I want to merge are 1h34m and 14m long respectively.
I tried VOBmerge, combined all the vob's in the VIDEO_TS to one big file. The resulting "merged.vob" was only 39 minutes long when played in VLC.
Haven't tried the vobedit/ifoedit method yet as I have about 120 DVD's I want to process and I was hoping for a solution with fewer steps. -
The programs you suggested seem to be for combining several titles onto a DVD (or DVD image), but they remain separate titles. What I'm trying to to is select some of the available titles from a DVD, and then rip those titles to a single, merged output file, rather than individual output files for each title.
thanks anyway
LJ -
Check the properties of each title. For example, if the main movie is 16 X 9 and the other title is 4 X 3, strange things can happen. Main movie may have multiple audio tracks and the others only one, etc.
I use Videoredo when I want to join vobs. It will give an error message if the properties of the vobs don't match. -
Get Your Facts Straight
There, if anyone's interested :I wish that guide was still active.
http://web.archive.org/web/20070103000254/http://members.dodo.net.au/~jimmalenko/test.htm
The required tools VOBEdit & IFOEdit can be found on VideoHelp.Last edited by abolibibelot; 11th Nov 2016 at 12:18.
Merging multiple parts of one mp4 file into one file
By vaultedskies in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2011, 10:08 -
Merging multiple files as one video file?
By mikehende in forum Newbie / General discussionsReplies: 5Last Post: 10th Nov 2011, 07:28 -
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 20:11 -
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 01:32 -
dvd shrink: single large file or multiple small files
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 22:43
