I have some old 8mm Pal tapes from the early 90's that I recored on a borrowed camcorder when I was in Europe & Africa. I recently unearthed the tapes but have no means of watching them. Is there a simple, low cost method to convert the tapes to NTSC and put them on either my hard drive or a DVD?
Thanks.
Do you have a pal camcorder to play them back on? If not then you'll have to find a company that can do the transfer for you.
If you wanted to go online and buy a used pal camcorder than you could do the conversion yourself. Either choice will cost a bit.
But if there are only a handful of tapes I would suggest looking for a company to do the transfer. Since you would have no need for the camcorder that shoots a different format after you're done you'd be buying equipment for a single purpose and you could avoid that.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Just get PAL DVDs made. You'll lower quality converting to NTSC.
Almost all NTSC players (anything not made in Japan) tends to play PAL now.
Have a company do it -- it will be cheaper than importing a good VCR,
and better quality than using some cheap/crappy "converting VCR" off eBay/etc.Want my help? Ask here! (not via PM!)
Thanks for your advice guys. I had it in mind to just send the tapes off somewhere and have them converted and that's what I'm going to do. I do only have 5 tapes to be done, so I'm not going to invest in any equipment to do it myself.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
8mm tapes PAL with NTSC camcorder????
By igorv in forum Capturing and VCRReplies: 5Last Post: 11th Oct 2010, 14:17 -
Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
By scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 13:49 -
By scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 01:34 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
