My source (mkv) is from an anime I downloaded with soft subs. I tried using ripbot264 to convert it to mp4 with hardcoded subs. The result is A/V being out of sync.
I think I did what must be done to convert the video. But now I'm stuck with A/V out of sync problem. What could be the causes?
1. I'm just using ripbot264's audio copy
2. video is lagging behind audio. the lag difference between the two gets more and more obvious over time.
3.
General
Unique ID : 186467362119441077125329412832932085312 (0x8C484EC136227FBD99227D3D4E533E40) Complete name : D:\[HorribleSubs] Kore wa Zombie desu ka - 06 [720p].mkv Format : Matroska File size : 287 MiB Duration : 24mn 41s Overall bit rate : 1 624 Kbps Encoded date : UTC 2011-02-14 18:02:50 Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Cover : Yes
Video
ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : V_MPEG4/ISO/AVC Duration : 24mn 41s Nominal bit rate : 1 500 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.810 fps Original frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.068 Writing library : x264 core 98 r1629 2e81ce1 Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=3486 / vbv_bufsize=3487 / ip_ratio=1.40 / aq=1:0.50 / nal_hrd=none
Audio
ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : A_AAC Duration : 24mn 41s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy
Text
ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Compression mode : Lossless -
for those interested, i got my source from
http://www.nyaa.eu/?page=torrentinfo&tid=193962
Hardcode subs at dvd5 movie
By Grohnheit in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 14:17 -
Hardcode subs on .m2ts???
By LoveMyslf in forum Video ConversionReplies: 6Last Post: 15th Sep 2010, 16:28 -
Hardcode Subs
By Gh0st Rav3r in forum SubtitleReplies: 1Last Post: 16th Oct 2009, 16:47 -
How to hardcode subs in .MKV
By CERO in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2009, 10:21 -
hardcode / burn the subs on the video
By greendesert in forum Video ConversionReplies: 1Last Post: 20th Jul 2009, 11:55
