I have installed Handbrake, but I can't get it to run. When I click on the icon, I get a window telling me that my display is only 853x683 and needs to be 1024x620 or higher. My screen resolution is set at 1280x1024. What do I need to do to get the program to run?
You're right... last version removed that option... (upscaling).
I think you got confused by the word "display". That is actually referred to the size your video will be displaied on your monitor.
So my advice is to choose a resolution expressed in squared pixel..
In handbrake Picture option do like this:
1) Check eventually crop options... automatic/custom... crop if you need, otherwise set custom 0/0/0/0
2) Set Anamorphic LOOSE and Modulus 16
3) Work on the width, keep in mind that there's no need of upscale.
Let's say you have a 16:9 video... you will set something 768x432 848x480 1024x576 1280x720 (with no need of upscaling)
in case of a 4:3 source go for 640x480 768x576 1024x768 and so on...
All clear? -
I guess you are using latest version? You could ask/report the bug in https://forum.handbrake.fr/viewforum.php?f=23 .
Or else use Xmedia Recode. It has also profiles for lots of cell phones.
elmuz: Phonematt can't even start handbrake.... -
That's OK, Elmuz, I do the same thing. Thank you both for your replies. I'll try Xmedia Recode when I get home.
Matt -
[QUOTE=elmuz;2064543] All is not lost. At least you explained what this stuff about "display" really meant. Prior to your post I was completely baffled as to why Handbrake would possibly care about the display size of the monitor where it was running.
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 02:09 -
Handbrake Setting for Sprint EVO HElp!
By DravenJ in forum Blu-ray RippingReplies: 0Last Post: 10th Jun 2010, 09:33 -
Anamorphic Setting in Handbrake - I'm Confused!
By w6rlf in forum Video ConversionReplies: 1Last Post: 20th Feb 2010, 12:06 -
problem with avidemux and handbrake
By volam1 in forum EditingReplies: 5Last Post: 4th Oct 2009, 08:52
