Results 1 to 10 of 10
    May 2009
    Hi
    I bought and have been using tmpgenc xpress for quite a while as its always done what i need - covert from one format to another with ease, has basic editing abilities and can read lots of formats including dvds.
    however it seems more and more that I'm using formats it cannot handle like mkv and youtube movies.
    I'm just wondering if there is any other software around that has the same functionality but works with more modern formats as well as old ones?
    thanks
  2. Avidemux perhaps?
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Format factory is a good jack of all trades with lots of input and output options. It can also be customized to a high degree in terms of ratio, bitrate and subtitles and things like that.
    For regular dvd creation avstodvd is an excellent choice.
  4. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I believe this is the "Best all round tool"
    Donadagohvi (Cherokee for "Until we meet again")
    Nov 2000
    Canada
    If you want to stay with Pegasys products maybe this:
    https://www.videohelp.com/tools/TMPGEnc_Xpress?nextcomments=25&orderby=
    I believe this is a fair contender:
    Oct 2005
    666th portal
    there isn't any 1 tool to do all conversions well. find the proper one to do the job at hand. there are lots of excellent freeware programs out there to cover most bases. xmediarecode, mediacoder, handbrake, bdrebuilder, multiavchd, avstodvd, and list just goes on....
    Nov 2002
    I believe Virtualdub belongs on this list also. With the new input plugins like FLV input plugin (264/aac), MKV input plugin, Directshow input driver and the new external encoder feature which allows the creation of MKV, MP4, AVI or MPG with commandline encoders like ffmpeg.exe, x264.exe, neroaacenc.exe, Lame.exe, MP4box.exe and MKVmerge.
  9. Mod Neophyte redwudz's Avatar
    USA
    ian_g, I changed your thread title to better describe your subject, as per our rules.
    Moderator redwudz
    May 2009
    Thanks for this, I wasnt aware of the new software but i played with the trial this morning and it looked great so i bought it - luckily i also got an upgrade discount too
