Results 1 to 14 of 14
  1. Hi
    So i got a hold of an untouched bluray extras file .m2ts and i would like to mux it into .mp4 without converting it. I know that you can create an mkv file using tsmuxer and mkvtoolnix so my question is, does any program exist like that but to .mp4 without any quality loss?
    Try a mp4 multiplexer like yamb or mymp4boxgui. You might have to demux the the video and audio tracks with tsmuxer first and import the multiplexers.
    It might also work xmedia recode and avidemux, open the m2ts and under video and audio choose copy, save as a new mp4.
  3. Originally Posted by Baldrick View Post
    Thanks for fast reply. I demuxed it with tsmuxer and tried mymp4boxgui and no errors but theres almost no video. Video freezes alot and there lines going through the middle. Any help?
    Video
    Count : 119
    Count of stream of this kind : 1
    Kind of stream : Video
    StreamKindID : 0
    Menu ID : 1
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Url : http://developers.videolan.org/x264.html
    Format profile : High@L4.1
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2
    Codec : AVC
    Codec : AVC
    Codec/Family : AVC
    Codec/Info : Advanced Video Codec
    Codec/Url : http://developers.videolan.org/x264.html
    Codec profile : High@L4.1
    Codec settings : CABAC / 2 Ref Frames
    Codec settings, CABAC : Yes
    Codec_Settings_RefFrames : 2
    Duration : 182500
    Duration : 3mn 2s
    Duration : 3mn 2s 500ms
    Duration : 3mn 2s
    Duration : 00:03:02.500
    Bit rate : 12111673
    Bit rate : 12.1 Mbps
    Width : 1920
    Width : 1920 pixels
    Height : 1080
    Height : 1080 pixels
    Pixel Aspect Ratio : 1.000
    Display aspect ratio : 1.778
    Display aspect ratio : 16/9
    Frame rate : 23.976
    Frame rate : 23.976 fps
    FrameCount : 4380
    Colorimetry : 4:2:0
    Scan type : Progressive
    Interlacement : PPF
    Interlacement : Progressive
    Delay : 5158000
    Delay : 1h 25mn
    Delay : 1h 25mn 58s
    Delay : 1h 25mn
    Delay : 01:25:58.000
  4. So i tried yamb too but exact same thing happened. Black and grey screens just randomly show for a couple of seconds throughout the video. Any help would be appreciated!!!
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    You may have to reencode the source to your output. If so you could use ripbot264.
  6. Originally Posted by yoda313 View Post
    So there is no way i can mux it to mp4 without reenocding it?
    Oct 2005
    666th portal
    what's the mediainfo report on the source file?
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Check out winff or avidemux. I know winff can remux but I don't know if it has any limitations regarding source material. I am also not a heavy user of avidemux but it has many output options as well.
    But you should do what aedipuss suggests and post the information of the original file so we can tell more.
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Have you tried avidemux or xmedia recode as I mentioned earlier...
  10. Originally Posted by Baldrick View Post
    I tried xmedia recode and xvid4psp and same result. Trying avidemux now
  11. Originally Posted by aedipuss View Post
    General
    Complete name : C:\Users\User\Desktop\00004.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 279 MiB
    Duration : 3mn 2s
    Overall bit rate : 12.8 Mbps
    Maximum Overall bit rate : 48.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format settings, ReFrames : 2 frames
    Codec ID : 27
    Duration : 3mn 2s
    Bit rate mode : Variable
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.243
    Stream size : 263 MiB (94%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format profile : Dolby Digital
    Codec ID : 129
    Duration : 3mn 2s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 4.18 MiB (1%)
    Text #1
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 2mn 54s
    Delay relative to video : 2s 461ms
    Text #2
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 2mn 53s
    Delay relative to video : 3s 712ms
    Text #3
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 2mn 53s
    Text #4
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 2mn 53s
  12. Originally Posted by Baldrick View Post
    So i tried avidemux now, and no grey or black lines but video stutters and skips frames. I tried everything ...
  13. Originally Posted by Baldrick View Post
    Ok so thanks all for help. I finally got it. For anybody who has same problem as me,
    First i demuxed it with tsmuxer
    Then i muxed it into mkv with mkvmergegui
    Then i opened the mkv in avidemux and the video came perfect. Untouched and no stuttering.
  14. I'm a MEGA Super Moderator Baldrick's Avatar
    Thanks for posting your solution.
