Hey all,
I recently bought a new set of headphones which allows the connect of optical cable. When i play back through VLC i get the best sound by selecting the A/52 over SPDIF option from within the audio right click menu. The problem i am having though is that most of the videos i play back through VLC play sound for 1 second then stop playing sound all together on this option, only a few videos allow the play back through this option.
Ive searched through the forums and came across :
Go to [Preferences] and check [Advanced Options]
Then Expand [Audio] and select [Output modules]
Change [Audio output module] to [Win32 waveOut extension output]
Then click on [Save] and quit and re-start VLC
Which didnt seem to make a difference.
Anyone got any ideas?
Thanks in advance![]()
Welcome dove32
Use media info to determine if the video with issue contains 5.1 audio ... if not it may be you need something like ffdshow to compliment audio output between the playback program and the systems hardware ... something to test as vlc has it's own inbuilt decoders.
Splitting AC3 Dolby Digital 2.0 (surround) into seperate WAVs?
By Asaki in forum AudioReplies: 2Last Post: 29th Apr 2011, 14:18 -
BLUE RAY to MKV Size still very large no digital sound or surround
By Androlantis in forum Blu-ray RippingReplies: 4Last Post: 25th Sep 2009, 00:41 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 22:32 -
can't get Surround from TV's digital audio output
By akrako1 in forum DVB / IPTVReplies: 6Last Post: 2nd Jul 2008, 17:38 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 17th Aug 2007, 23:49
