I record our church services on Sunday Morning. I have 3 camras hooked to an edirol 4 channel live switcher.. I need to record on 2 DVDs at one time. Is there a duel DVD recorder that will record 2 dvds with the push of one button?
Results 1 to 12 of 12
Yes,
When were done we send 2 disk to 2 different TV stations . Thers no time to duplicate. -
KevinBon, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
You could just get two of the same recorders and use the remote. That would trigger them both.
Distribution amp, two recorders.
Easy.
Get this for $115 + shipping:
Datavideo VP-299 Distribution Amplifier @ http://www.bhphotovideo.com/c/product/216915-REG/Datavideo_VP_299_VP_299_A_V_Distribut...3167/KBID/4166
Then add a DVD recorder. I suggest a good one, either
(1) Panasonic DMR-EZ28K DVD Recorder, $200 at http://www.amazon.com/gp/product/B0014F7Z94/ref=as_li_ss_tl?ie=UTF8&tag=thdifa-20&link...SIN=B0014F7Z94
(2) Toshiba DR570 DVD Recorder, $157 at http://www.amazon.com/gp/product/B001TOD3KK/ref=as_li_ss_tl?ie=UTF8&tag=thdifa-20&link...SIN=B001TOD3KK
Not some random crap from the "local" store (Best Buy, Walmart, etc)Last edited by lordsmurf; 14th Mar 2011 at 01:46.
And to answer the original question, I doubt if such a unit exists. In the UK we have a Sky+ box which has twin tuners and is capable of recording separate signals on to internal HDDs at the same time. But I have never seen a unit with twin disk recorders.
So the above suggestions are appropiate and as hech54 states if you have access to a PC burner you can duplicate a single disk in less than 20 minutes(allows for creating the image and writing it to a blank disk). Surely you can spare 20 minutes ? -
You say no time to duplicate, but doesn't that only take like 5 minutes @22x?
If it was a file you could just post it on the net & everyone could get it right away. -
Maybe relative disk-burning speeds are OT here and while there does exist 22x burners is there actually any 22x certified blank media ?
I quoted 20 minutes simply as, possibly over-cautiously, I always burn my 16x media at 8x. The burning time is then longer but I do believe that burns are less liable to go bad. And the last thing the OP needs is a bad copy.
I can't get my Wharfdale DVD recorder to record in 16:9
By AndyLGR in forum Newbie / General discussionsReplies: 7Last Post: 12th Jul 2011, 09:27 -
DVD Recorder will only record when TV is switched on
By jiminwatford in forum DVD & Blu-ray RecordersReplies: 23Last Post: 18th Apr 2011, 15:03 -
Can a DVD recorder record stuff from AV?
By xtube in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2010, 08:29 -
HELP PLEASE!! Can i record an AV channel on DVD recorder HELP PLEASE
By Lilman02 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Apr 2010, 15:55 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 13:37
