Hey,
I have a somewhat technical query, which i hope someone can assist with. The question is in the context of an xvid encode.
When a first pass stat file is being used to do a second pass encode, to what extent is the encoder looking at the first pass stat file. i.e. whilst the second pass is encoding, is it:
Thanks in advance.
- Looking at the whole of the stat file infront of the frame until the very end; or
- Is it only looking a certain number of frames ahead (e.g. 300 frames).
I believe it has to examine the entire stats file at the start of the second pass. Then reads through the file frame by frame while encoding.
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 02:13 -
How to continue with 2nd pass if you have .stats and .mbtree files?
By ad.vid in forum Blu-ray RippingReplies: 1Last Post: 21st Dec 2010, 14:28 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 16:18 -
Removing subtitles, running 1st pass again?
By moviebuff2 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 07:20 -
Virtualdub, 2pass - 1st pass statsfile not found
By kidcash in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2007, 04:05
