I had VirtualDubMod 1_5_10_3 and 2. They worked individually and also in other included programmes. I read somewhere that it can't be dragged but can be copied by cut and paste method to other programmes/folders. I did so. Now, it doesn't open in any of the programmes. I deleted all, downloaded fresh. The same condition prevails. Can someone help me.
Thanks.
Results 1 to 11 of 11
Yeah, VirtualDubMod is quite dependent upon all of its files and subfolders.
shans: Cutting and pasting is essentially a file move, you know.
What were you trying to do, exactly?
If cameras add ten pounds, why would people want to eat them? -
Actually, I did copy and paste only and NOT cut and paste. I copied .exe file with other files into another program in a different folder. Since then, when I double clicked the .exe file, it doesn't execute both in copied from and copied to folders. Then, I deleted all and downloaded afresh pack, unzipped and tried to open the .exe file. Nothing opens. Shortcut of the VDM exe from the original folder also doesn't work.
Try deleting the VirtualDubMod entries in the Registry:
HKEY_CURRENT_USER/Software/Freeware/VirtualDubMod -
Yes, I did as you said. Restarted the system. Double clicked the VDM .exe. Licence agreement screen opened. Clicked the "OK" highlighted ikon. I thought the VDM will open. But, nothing happened.
Anyway, I again opened the Registry to see what happened. Here is the screenshot :
Can you please instruct me the next step. -
I un-installed the Avisynth along with plug-ins totally from directories. Deleted VDM also. Installed them only in the root directory. Now everything works perfectly. When I did some exercises in DivxMediaBuilder, where avisynth and vdm are functionaries, some problem might have caused. Now, the problem is solved and VirtualDubMod works individually and also in other programmes.
Thanks.
Problem: Sony Vegas doesn't open !
By freestyler09 in forum Software PlayingReplies: 6Last Post: 22nd Feb 2011, 14:59 -
can't open any videos in vdubmod 1.5
By mr-scarface in forum EditingReplies: 8Last Post: 18th May 2009, 04:53 -
Open Office 3.0 gets rave reviews; the release doesn't
By ahhaa in forum ComputerReplies: 1Last Post: 15th Oct 2008, 09:17 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 16:39 -
Windows Media Player Doesn't Open
By kerrex_2006 in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2007, 20:22
