    Aug 2007
    Just installed a hauppage 2550 dual tuner card. How do I record two different programs using wintv 7? The only way I am doing it now is using wintv 7 application to record one channel and then opening windows media center to record the second channel at the same time. There must be a way to use just one application to record to channels/sources?? Help please i sure its simple just can't figure it out.
    Aug 2006
    You need to set up each of the tuners in Windows Media Center. It should see all of them.
