I have Vegas 9.0 Pro. On an avi file, there's a patch of audio that produces a 30 sec or so squeal. I'd like to eliminate it. When I try to select an audio editor, there is really nothing to select. I do not have a current version of Sound Forge. It's about 4 years old and not installed. Was I supposed to get a sound editor when I bought 9.0? Maybe there's another way to get the squeal out but preserve the audio of someone talking. I think the noise came from a nearby electronic source.
Results 1 to 10 of 10
Very simple "trick": Audacity can open the AVI file and extract audio by itself. (If you have installed the ffmpeg plugin.)
Then edit it, save it back to a compatible format (Eg, MP3 CBR 160 or higher rate) and replace the original audio with the new audio (presumably Vegas can do that; I don't use it). -
Hmmm, I thought I responded to the above. I just decided to just the WAV suggestion using vdbub. Works fine.
The install did not create an item in the Start menu of Win 7. Anyone know how to do that? -
If it's a .exe file, it may not add itself to the start menu, but you can pin it there manually, or pin a shortcut there.
You can set any audio editor in Preferences/Audio Tab. Then right click the audio and it should show up.
Audio Editor - Batch
By BobAchgill in forum AudioReplies: 2Last Post: 3rd Nov 2011, 07:43 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 02:17 -
Just getting started on audio--removing a squeal with Audacity
By solarblast in forum AudioReplies: 13Last Post: 14th Mar 2011, 12:17 -
[Q] good audio editor
By Csubakka in forum AudioReplies: 4Last Post: 27th Nov 2010, 11:28 -
How do I uncensor a censored audio track in an audio editor?
By adidasos in forum AudioReplies: 1Last Post: 19th Jan 2009, 06:40
