Hello,
I am getting ready to buy a laptop for running Mastercam and SolidWorks Cam/Cad stuff. I can only spend about $1100. What would you recommend? I pretty sure I want a i7. just not sure which video card to get and what laptop brand. Here is a couple I am looking at. What is the difference between the Intel Core i7 2620M & the Core i7-720QM Processors.
http://www.amazon.com/Republic-Gamers-G51JX-A1-15-6-Inch-Gaming/dp/B0034NGZWM/ref=sr_1...871755&sr=1-28
http://www.qvc.com/qic/qvcapp.aspx/view.2/app.detail/params.item.E246944.desc.Dell-XPS...B.cm_scid.zone
If your apps. require a workstation class video adapter, the Dell Precision series may fit your needs as they have Nvidia Quadro FX graphics adapters in them.
http://www.dell.com/us/business/p/precision-m4500/fs -
For cad/cam get the largest screen you can afford. The dells are only 15 inches. I would look at Sagar notebooks but some models cost more then your budget.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Quadro DVD HT 1100 new firmware
By betmeb in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Aug 2009, 18:15 -
Why is an 1100 bitrate giving me a 6.5gb file when before it gave me 1.1gb?
By happyprozak in forum Blu-ray RippingReplies: 1Last Post: 27th Nov 2008, 14:10 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40
