OK so my friend has an xbox, a laptop, and a 1080i HDTV set (the older ones). He streams the videos stored on his laptop through the xbox onto the TV.
Now I want to borrow his xbox from him for a month or so. But he won't be able to watch his videos if he doesn't have the xbox.
So I told him that I'll buy a cable that allows him to connect his laptop directly to the TV. The laptop only has a VGA output, while the TV only has a DVI input. So I need a VGA to DVI cable. Our local stores unfortunately don't carry these, they only have the adapters and not the cables. Anyone ever had any issues with these?
Results 1 to 9 of 9
VGA to DVI adapters/cables will only work if the DVI port on the TV is DVI-I or DVI-A. Look at Wikipedia to find out how to identify the type of DVI port present on the TV.
I'm pretty sure this is the TV:
http://www2.panasonic.com/consumer-electronics/support/Televisions/CRT-Projection-TVs/...PT-53WX53.T#ts
It says it has DVI-HDCP. Another thing I should mention is that I've been able to connect my own laptop to this TV in the past, by using an HDMI to DVI cable, and it worked perfectly. -
Hehe I'm super-confused right now. All I know is that it was a monster brand cable, and it worked fine.
The one I want to buy for my friend's laptop is this:
http://vancouver.kijiji.ca/c-buy-and-sell-computer-accessories-VGA-to-DVI-Cable-6-Ft-W...AdIdZ264266205 -
I found a small picture in the TV manual and a picture of a DVI-HDCP connector here http://www.tech-faq.com/dvi.html. It's a DVI-D dual link port. There is no chance a DVI to VGA adapter or cable will work. VGA is analog RGB, DVI-D is digital only. It has no pins for transmitting RGB.
Damn that sucks. I appreciate you looking into this though.
Are there any workarounds to the problem? -
No cheap ones. You would need a VGA to DVI converter. They start at about $100. Here's an example. http://www.solidsignal.com/pview.asp?mc=13&p=AVH100F&d=Aluratek%20AVH100F%20VGA%20to%2..._HDMI_Supplies
I never tried one, and have no idea if it this or any similar device truly provides a satisfactory result
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
VGA to DVI-D cable
By ljCharlie in forum DVB / IPTVReplies: 22Last Post: 13th Jan 2010, 14:07 -
Help! Mac Mini (dvi or vga) out to Component Cable in on Projector
By soundsinamotion in forum DVB / IPTVReplies: 3Last Post: 7th Dec 2008, 23:40 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 07:49 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 21:37
