  1. hi,
    i have logitech z506 5.1 speakes and i want to connect with my sony blu ray. but in blu ray have HDMI, SPDIF ro coaxial and
    these connection are not in 5.1 its have only pc 5.1 (stero jeck) and RCA (only Stero R & L) jacks which only connect my lcd tv.
    Those Logitech speakers have no digital inputs, and your BD player only has digital outputs, so you can't connect them to your BD player.
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    You will need some form of receiver that the speakers can connect to....Good Luck
    Aug 2006
    You would need a sound card that accepts digital 5.1 audio via S/PDIF input and converts it to analog for your speakers. Unfortunately, new sound cards can't do that. Technology licensing does not allow sound cards to perform the necessary digital to analog conversion anymore.
    I was involved in a thread started by someone looking for a Sound Blaster Audigy 2 ZS Platinum Pro because he wanted a sound card with the following attributes:
    1.) can *decode* DD and DTS
    2.) has a TOSLink optical digital input that accepts DD/DTS 5.1, not just stereo PCM
    3.) has a TOSLink optical digital input that works with the analog output, meaning it will convert the digital 5.1 sound to analog 5.1 output
    4.) has multi-channel analog output
    5.) has PCI slot
    The Sound Blaster Audigy 2 series dates from 5-6 years ago, and is now discontinued. You must find a used one. You will need the sound card, a matching audigy drive, and some other accessories. It may be difficult to find everything.
    However, I don't know enough to say for sure if it is really a solution for you, but maybe someone else does.
  5. Originally Posted by Bodyslide View Post
    i know that but you know any receiver or converter that have stero jeck inputes in and digital outputs. i found RCA recivers
    not stero jecks.
    thanks
  6. DECEASED
    Jun 2009
    Heaven
    not stero jecks.
    Well, apparently that's the "norm".
    Anyway, it's not exceedingly-difficult to find (or to build) P2-to-RCA adapters
    Aug 2006
    This is an example of the kind of adapter El Heggunte is suggesting. They are very inexpensive.
